trouble codes 410,133,&140. (secondary air & o2 sensor)
pburnhamb
Year and Model: 1998 v70
Postby pburnhamb » Tue Sep 13, 2011 7:35 pm
so i have a 1998 v70 that has been throwing the check engine light on. i pulled codes 410 (secondary air system malfunction), 133 (o2 sensor ckt slow response ...bank 1 sensor1), and 140 (o2 sensor ckt no activity....bank 1 sensor2). i replaced the o2 sensor on the down pipe. i also took the computer out and soldred a rect dio between the 2 correct wires as described on a couple posts. i am still getting codes 410,133 & 140.......gulp. if i clear the odbII codes with the reader they come back and at the same time the "abs" and "tracs off" lights light up on the dash. where do i go from here (not the dealer). thank you all.-patrick-
vjaneczko
Year and Model: '97 855 GLT;'06 S60R
Flag: United States of America
Re: trouble codes 410,133,&140. (secondary air & o2 sensor)
Postby vjaneczko » Tue Sep 13, 2011 8:02 pm
The ABS & TRACS lights usually come on when the ABS module fails, but never at the same time as the CEL - but it does sounds like you have two seperate issues (actually three).
ABS Module: Check Matty Moo's profile, who repairs the modules for a decent price. Also check for Ozark Lee's write-up on repairing it yourself if you're handy with a soldering iron.
SAS Delete: double-check the wiring you did. I've not done it (yet) but I'd be nervous about touching the wrong wire in there. Did you remove the parts related to the SAS or did you leave them in place? I'd yank 'em if you didn't.
O2 sensors; I'd take a look at them to see if they're coated with soot. It might also be time to replace them, but I don't think I've seen anyone post that they both go out at the same time. Any black, blue or white clouds coming from the tailpipe?
1997 855 GLT - Now for my daughter
2006 S60R - For ME!
pburnhamb
Postby pburnhamb » Tue Sep 13, 2011 8:09 pm
i did replace the front o2 sensor with a bosch one (the correct one) i cant find the link i used to do the ecu soldering job ...anone have it?? . but read in another link that there was some discrepencies as to which two pins needed the rectifier diode between them........as for te ABS thank you for the lead. i hate emissios checks. no smoke at tailpipe and runs well...???
vjaneczko
Postby vjaneczko » Tue Sep 13, 2011 8:18 pm
2006 S60R - For ME!
pburnhamb
Postby pburnhamb » Tue Sep 13, 2011 9:01 pm
ok.thanks for sending that link. i used some other one that reqired me to solder one on A side and ne deep down on Bside. didnt work and wasnt easyto get at. just did it the way thelink above sad to A side to Aside. we will see how it works in the coming days. i will check into the abs issue now, though im not as concerned with it as the o2 issue and emissions in general as i need to get this thing registered so i dont have to drive it another year illegally.any ideas onthe o2 issues??? will report back, thank you much for help.
turbozutek
Year and Model: 1995 850 GLE
Postby turbozutek » Wed Sep 14, 2011 11:16 am
When a few separate computer controlled systems start acting up at once for seemingly no reason, I'm always tempted to check the battery voltage and charging voltage.
Low voltage = all sorts of electrical oddities. It's a quick check and worth doing maybe?
Chris...
pburnhamb
Postby pburnhamb » Fri Sep 16, 2011 8:24 pm
ok, so soldering the rect diode like the link shows worked great. the only code i have now is p0133. o2sensor ckt slow response....#1 bank 1.....what does this mean.???? im gonna do some research on this site from later posts to see if any thing turns up. maybe start a new post if i dont find anything..???any ideas. im getting close to having no check engine light on i can feel it!. THANKS -patrick-
frisby
Year and Model: v70 1998
Postby frisby » Thu Nov 14, 2013 3:50 pm
I have a 1998 Volvo V70 and I have a check engine light on. I was told it might have to do with the waste gate and the calibration. I have black soot coming from the tailpipe and the exhaust smells something awful. Any ideas on what it is and how to correct the problems would be greatly appreciated.
vjaneczko
Postby vjaneczko » Thu Nov 14, 2013 4:00 pm
Frisby, welcome to the forum.
There's a ton of reasons why the light is on, so you'll have to determine what code has been set to cause the CEL to go on. If you don't have an ODBII scanner, head over to an AutoZone, NAPA, or any other parts store and they'll most likely scan it for you. Once you get those codes, Google them or start a new thread and post them so we can point you in the right direction.
2006 S60R - For ME!
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot], ecbsykes, Matty Moo, MSNbot Media, Yahoo [Bot] and 35 guests
