Volvo 850 1996 GLT - Odometer and speedometer stopped
Jack_Inaboxx
Year and Model: 1996 850 GLT
Postby Jack_Inaboxx » Wed Feb 22, 2012 1:29 pm
Hello everyone,
first of all thanks for all the tips that this board has given me, but now I just arrived at work and encountered an issue that I need to fix asap.
So basically, on the last 500m on my way to work, the odometer AND speedometer just spontaneously stopped working. Both just... aren't reading anything. I went around the block to see if something would happen, but nothing.
Now I am wondering if it is a gear issue - that only affects the odometer, or an ABS module issue - I have done a little bit of research.
Yes - the ABS check light is on, but only sporadically, mostly when I brake (but othertimes no). Other CEL include the oxygen sensor (lambda), but that is completely unrelated IMHO.
So my question is - what do you think it is? Should I repair/replace the ABS unit, go with the gear change, go for both, or something I didn't think about?
On a completely unrelated note - how many meters of vacuum tubing does one need to change the whole vacuum line in a non-turbo 850?
Thanks again,
-Jack-
xHeart
Year and Model: 1997 854 NA
Flag: United States of America
Re: Volvo 850 1996 GLT - Odometer and speedometer stopped
Postby xHeart » Wed Feb 22, 2012 2:41 pm
There are many threads here at MVS on this topic.
Get started with viewtopic.php?f=1&t=32798
Or this viewtopic.php?f=1&t=46680
Golden Retriever | 2014 VIDA DiCE | 2001 Volvo V70XC with +168kmi/ +270kkm | 1997 Volvo 850 NA (2.5L/5) Sedan with +147kmi/ +237kkm
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
Jack_Inaboxx
Postby Jack_Inaboxx » Wed Feb 22, 2012 3:10 pm
Thanks a lot! I just needed to know if it was an ABS module problem or a odometer gear problem... just sent a message to Matty Moo on his ABS module repair site to get a shipping quote to Canada, now waiting for his reply.
Thanks again, now this should be a jiffy to fix.
-Jack-
xHeart
Postby xHeart » Wed Feb 22, 2012 5:50 pm
What not to do Jack viewtopic.php?f=1&t=46009
Jack_Inaboxx
Postby Jack_Inaboxx » Thu Feb 23, 2012 12:23 am
I replaced my PNP a month ago and went through the air cleaner base too, as well as before cleaning up the PCV and IAC... I'm actually lucky I didn't break that part the first two times. Thanks for the heads up, and hope you got that fixed. Just ordered the fix from Matt... excited for it to come.
I'll post a follow-up the moment I send the defective ABS to the States.
Now here's a list of everything that I still need to do on it, in order:
- Change front catalytic oxygen sensor (for higher MPG, and get rid of all those dashboard warning lights :D)
- Change rear shocks (been pushing my steering left...)
- Return the used blower fan I bought because it started screeching as bad as the old one, and hope I get one that works this time.
- Adjust trunk and put the spoiler back on
- Replace vacuum lines
- Change dashboard/automatic transmission lights, and other cosmetic stuff.
Then at 200,000 km, timing/aux belt. Gah.
-Jack-
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: abscate, Matty Moo, Yahoo [Bot] and 27 guests
