Please don't use image hosting services like Image Shack. Here's why. That's from 2009, and it still holds. The forum software is better than ever at uploading and storing photos, and it's easy.
cruise control not working
scottg
Year and Model: 1993 850 GLT
Postby scottg » Sun Feb 26, 2012 6:46 pm
I have a '93 850 GLT and the cruise does not work. I have replaced the brake vacuum cut-off switch, the control module, the switch tree and still nothing. I don't even hear the vacuum pump working. I did run some tests and could make the vacuum pump work with jumper wires placed on the posts under the control module, but it doesn't seem to come on when needed. The other tests I've run showed the "-" side of the selector switch was bad, ergo its replacement. The brake cut-off switch I had to replaced because I broke it messing around under the dash. I am pretty sure it is adjusted correctly. The only code I get from the diagnostics is a 1-2-2, no speed detected (or sometihg like that).
Any ideas? When should the vacuum pump come on?
rspi
Flag: United States of America
Re: cruise control not working
Postby rspi » Sun Feb 26, 2012 7:54 pm
Go for the simple stuff first. Check vacuum lines, mine were worn through under the battery box. Then I had a linkage broke at my gas pedal (from the servo pump).
'95 855 T-5R, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red
Volvo's of past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow
Donate Today - Volvo Repair Videos
Year and Model: Many Volvos
Postby Ozark Lee » Wed Feb 29, 2012 5:19 am
Most of the time the hard plastic line from the vacuum pump to the firewall is cracked. Have you installed the jumper wires into the cruise relay sockets to verify that the pump itself is working?
It sounds like you have done all of the DTM-2 tests already.
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
scottg
Postby scottg » Fri Mar 02, 2012 1:41 am
I have run the jumpers under the control module and the pump starts up jsut fine. I pulled the pump out and inspected the hoses, and all seems fine. When does the vacuum pump start up? When the car runs or when asked to by the cruise?
Year and Model: 850s, 98 S/V70s
Postby erikv11 » Fri Mar 02, 2012 2:30 am
Vacuum pump starts up when the cruise is activated, when you actually set a cruising speed.
'96 NA 855 | 129 k
'95 T5-R 854 | 180 k
'98 V70 GLT | 15g turbo | 251 k
'98 S70 NA | 174 k
gone: '96 NA 850 210k, '98 NA V70 182k
scottg
Postby scottg » Fri Mar 02, 2012 2:48 am
Thanks. I NEVER hear the thing running at all and the cruise doesn't even try to engage. I'm getting stumped over this one. New brake cut-off switch, new control unit, new switch tree, still nothing!
Year and Model: '98 S70 T5
Postby MadeInJapan » Fri Mar 02, 2012 11:00 pm
I had the same problem, it was a broken wire right under the switch on the stalk at the steering wheel- it will come apart fairly easily. Look in there- all I did was use a piece of solder and tape and mine worked again.
94 850 Sedan NA Drk Blue/Tan
'00 V40 Purple/Grey - SOLD
rspi
Postby rspi » Sat Mar 03, 2012 3:22 am
My linkage between the vacuum servo and the gas pedal was loose.
scottg
Postby scottg » Sun Mar 04, 2012 4:50 pm
I've checked and metered the wiring to the switch and all tested just fine. As I meter the tree switches, all test just fine. The "-" part of the switch tested bad at the point under the control unit which is why I replaced the tree. All fuses are good, but I am nearly convinced it's an electrical problem somewhere, but I don't know where.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: erikv11, esl_97_850_T5, JDS60R, Ringo and 27 guests
