V70 Right Lower Motor Mount Replacement
rmmagow
Year and Model: V70 1998
Postby rmmagow » Fri Mar 16, 2012 8:01 pm
Hi All,
I will look deeper but, I am changing my motor mount on a 98 V70 tomorrow the one near the crank. Looks easy enough. When putting the new one in, should I bolt the motor side first and jockey the thing so I can put in the frame mount bolts or do it the other way around. I'll be jacking the motor up carefully and will have a second pair of hands to help. I had something saved on my other computer, but it is long dead.
Thanks,
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmmagow
Re: V70 Right Lower Motor Mount Replacement
Postby rmmagow » Fri Mar 16, 2012 8:04 pm
xHeart
Year and Model: 1997 854 NA
Flag: United States of America
Postby xHeart » Sat Mar 17, 2012 12:04 am
Your how-to with photos could be a timely contribution as previous MVS posts are several years old, and fast becoming obsolete. TIA
Golden Retriever | 2014 VIDA DiCE | 2001 Volvo V70XC with +168kmi/ +270kkm | 1997 Volvo 850 NA (2.5L/5) Sedan with +147kmi/ +237kkm
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
BKM98 S70 T5
Year and Model: S70 T5 98
Postby BKM98 S70 T5 » Sat Mar 17, 2012 6:45 am
rmmagow wrote:Hi All,
Thanks,
I just looked at mine today while installing my last front Strut Assembly and the Mount is totally bottomed out. Read somewhere it is easier to loosen the 2 small bolts during removal so you can raise the engine as it is sitting lower so making it more difficult to get to the larger Frame Bolts? I believe it said to do otherwise when installing; frame bolts first.
I am considering these and i think they are the same.
http://www.ebay.com/itm/Volvo-Engine-Mo ... 6030921077
http://www.ebay.com/itm/Volvo-Engine-Mo ... 1677604670
rspi
Postby rspi » Sat Mar 17, 2012 8:59 am
BKM, you are right. I just did the mount in my wagon yesterday and I needed to pull the side bolts first, easier. I updated those instructions.
'95 855 T-5R, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red
Volvo's of past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow
Donate Today - Volvo Repair Videos
rmmagow
Postby rmmagow » Sat Mar 17, 2012 6:45 pm
Got too cold today, tomorrow. rspi, I just realized those instructions were your's to begin with! Nice job. I just got a brand new Milwaukee cordless impact wrench today. This will be its baptism, taking off the wheel and maybe the side bolts on the mount but I'm guessing this is going to be a pretty easy job. The shop that did the TB for me said the car is really clean underneath, even the engine copartment is pretty clean w/no oil leaks. I like this car and will be getting another, 94~98 850/V70. I'm going to see about a regular GLT as the AWD isn't really needed. But a nice R would be pretty good too.
rmmagow
Postby rmmagow » Sun Mar 18, 2012 9:49 pm
This was crazy easy. Took less than an hour and this was my first time. Motor did need to be lifted qute a bit to line stuff up but truthfully, this was only marginally harder than changing a tire. Good opportunity to check under the car too. The mount I bought came with some type of aluminum spacer but it wasn't needed. Engine buzziness is gone. Car feels great. Next up is fixing the P0243 and replacing some vac lines. Things got 165K, I honestly think 250 isn't out of the question. I'm changing the tranny fluid next weekend but even the stuff in there now doesn't look or smell bad. Whoever owned this car took care of it.
BKM98 S70 T5
Postby BKM98 S70 T5 » Mon Mar 19, 2012 6:20 am
rspi wrote:BKM, you are right. I just did the mount in my wagon yesterday and I needed to pull the side bolts first, easier. I updated those instructions.
rmmagow wrote:This was crazy easy. Took less than an hour and this was my first time. Motor did need to be lifted qute a bit to line stuff up but truthfully, this was only marginally harder than changing a tire. Good opportunity to check under the car too. The mount I bought came with some type of aluminum spacer but it wasn't needed. Engine buzziness is gone. Car feels great. Next up is fixing the P0243 and replacing some vac lines. Things got 165K, I honestly think 250 isn't out of the question. I'm changing the tranny fluid next weekend but even the stuff in there now doesn't look or smell bad. Whoever owned this car took care of it.
Thanks for the info "rspi" and encouragement "rmmagow". My mount should arrive in couple of days.
http://www.ebay.com/itm/390263714447?ss ... 886wt_1050
precopster
Year and Model: Lots
Flag: Australia
Postby precopster » Mon Mar 19, 2012 11:04 am
The Febi Bilstein is the OEM mount and should last as long as the original. URO rubber can transmit some vibration to the cabin. Hope it works out.
Current cars: 2000 V70 non turbo, 1998 V70R AWD, 2001 V70 XC project, 2001 V70 T5, 2002 XC70
What we used to own:1995 850 sedan, 1987 740 sedan, 2002 S60AWD, 1989 740 turbo wagon, 1985 760 V6, 1995 850 wagon, 1999 V70 project car.
In forum posts please call me Mike
instarx
Year and Model: V70 XC SE, 2000
Postby instarx » Mon Mar 19, 2012 12:06 pm
Changing this mount is so easy to do there is very little downside to using URO brand. I put a URO mount on last month and there is no more vibration than the original mount, and at $62 it cost half of what a FEBI mount would have cost. URO does not have a good reputation here, but in an application where it is easy to replace and offers a significant cost savings it makes sense to use it. It also has a 2-year warranty. If it had taken 2 hours to install I might have gone for the $127 OES mount, but I can change this mount in under 30 minutes.
2000 V70XC SE - 184k miles
Total repairs over past 8 years: $1,660 ($207/year) but needs a new angle gear.
28-31mpg highway; 17-21 mpg city - accurately measured
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: erikv11 and 66 guests
