IPDVolvo PartsVolvo Salvage: Used Volvo Parts and Over 50 Years ExperienceSouthern Vo Vo sells genuine used Volvo parts
Volvo Parts
Buying gifts? Please use this Amazon link ... and help keep MVS on the Web. Thank you!Amazon.com
MVS Login
Register - it's Free!
Get Help
Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
Volvo Parts
Shopping Amazon.com? Help MVS by using this link!
What has failed on your 1992-2000 FWD or AWD Volvo?
Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
02 sensor
114
2%
a/c clutch, compressor, accumulator tank
57
1%
a/c evaporator, purge valve, pressure switch
44
1%
a/c receiver-drier
16
0%
ABS module
169
4%
airguide, skidplate
42
1%
alarm status indicator
8
0%
alternator
63
1%
ball joints
108
2%
battery cable
29
1%
bevel gear
14
0%
brake booster check valve
1
0%
brake caliper
59
1%
brake hoses
36
1%
cabin temperature sensor
20
0%
camshaft position sensor
37
1%
cargo cover on wagons
15
0%
center arm rest, release
36
1%
center hood latch, extension lever
27
1%
control arm
83
2%
coolant expansion tank, cap
78
2%
coolant hoses and clamps
60
1%
crank seal
16
0%
crank sensor
8
0%
cruise control, linkage at the gas pedal
17
0%
cup holders
122
3%
cv boots, axles
140
3%
dash ungluing
70
2%
defroster plate
9
0%
door catch, check strap, hinge
88
2%
door lock actuator
70
2%
door panel ungluing
86
2%
door-lock switch
38
1%
driveshaft
31
1%
ECC electronic climate control
25
1%
ECT engine coolant temperature sensor
40
1%
ECU air tube
21
0%
emissions air pump SAS, relay, valve
51
1%
engine mounts
140
3%
ETM
43
1%
exhaust hanger
46
1%
FPR fuel pressure regulator
8
0%
front washer pump
6
0%
fuel door latch
40
1%
fuel pump, relay
37
1%
glovebox lock
34
1%
grill retaining clips
20
0%
head gasket
14
0%
headliner ungluing
49
1%
heated seats, seat t-stat, seat wiring
55
1%
heater core, blower, resistor, lines
106
2%
IAC idle air control valve
13
0%
ignition coil, coil pack
50
1%
ignition switch, cylinder
35
1%
interior light dimmer
8
0%
interior switch, info switch
15
0%
keyless entry, remote or car
43
1%
MAF mass airflow sensor
100
2%
odometer gear
86
2%
outdoor temperature sensor
14
0%
parking brake cable
48
1%
PCV system
116
3%
PNP switch
28
1%
power antenna, cable
61
1%
power door locks
35
1%
power steering pump
12
0%
power steering rack
28
1%
power window module
20
0%
power window motor
13
0%
power window switch
58
1%
radiator
93
2%
radio, cd changer
41
1%
rear hatch latch
20
0%
rear main seal
35
1%
rear washer pump
30
1%
seat adjustment switch
28
1%
seat belt release
25
1%
seat cable
13
0%
seat leather, cloth surface
94
2%
shift solenoid
12
0%
shift-lock microswitch
28
1%
signal flasher relay
6
0%
speakers, speaker wires
48
1%
spring seats
46
1%
starter
27
1%
steering wheel
11
0%
strut mount
93
2%
sun visors
38
1%
sunroof
35
1%
sway bar link, end link, tie rod
100
2%
tailgate or trunk strut
75
2%
thermostat
73
2%
throttle control linkage
4
0%
timing cover seal
4
0%
transmission
32
1%
turbo oil cooler line, oil return, gasket, o-ring
53
1%
vacuum lines, elbows
99
2%
wheel bearing
66
1%
windshield washer tank
12
0%
windshield wiper arm, post
35
1%
Total votes : 4605
Re: What has failed on your 1992-2000 FWD or AWD Volvo?
Postby gbaxa3 » 28 Apr 2012, 23:04
Significant item missing, at least from my wallet's point of view, steering rack. Blew every seal on winter. Passenger front wheel bearing has failed three times in 10 years of ownership. Currently troubleshooting rear wheel, stay is broken, undetermined cable connection is sheared at splice near control arm. The joys of car ownership.
GB3
1964 P1800
1998 XC70
2012 C30
gbaxa3
Model and Year: XC70 1998
Postby aahmes57 » 12 May 2012, 09:20
Pretty much alot. Bought it for $3200 and I have about $2000 (not counting any misc labor) in parts in it. PCV system, both cam and crankshaft seals, oil coolant lines, struts, ball joints, axles, tie rods, rotors, ABS module, heated seat switch, rr window switch, rear shocks, t-belt and associated components, drivers seat switch, and a few others that escape me at the moment. Runs great at 190,000 so I guess I'll keep it.
1991 740 (saved a life)
1998 S70 Turbo
1995 850
aahmes57
Forum Member
Forum Member
Model and Year: S70 Turbo 1998
Postby mynorsyama » 18 May 2012, 20:37
Dashboard backlight
Horn switch
Radiator fan
Headlight switch
Internal Fan switch
Recirc valve
mynorsyama
Postby VTexan » 09 Jun 2012, 02:38
Radiator.
VTexan
New Member
New Member
Model and Year: 1995 Volvo 850
Postby Colonialgirl » 17 Jun 2012, 06:17
I just had to have the Cam Shaft Seals replaced on my 1998 S-70 (Non-Turbo) I was losing oil there like crazy; Thought it was the PCV Oil Separator, BUT after replacing the seals, they checked the crankcase pressure and found ALL to be normal.
BTW, If you are around Tampa or Brandon, FL; Bergman's Foreign Auto Service did an excellent job at a reasonable price and were up front about what was needed and didn't add on to the costs.
Colonialgirl
Forum Member
Forum Member
Model and Year: S-70, 1998
Postby Oddbob » 21 Jun 2012, 01:20
I forgot to check (1) shift-lock microswitch and (2) signal flasher relay for my 1996 850.
Other things:
    Misc lights in the dash/radio.
    Backlight for PRND3L.
    Driver window button fell apart.
    Speed sensor at trans went in and out.
    Steering column cover secures broke.
    Horns died early on.
The Good - 1995 850 Turbo
The Eh... - 2004 Ford Focus
The Dead - 1996 850 GLT - The bane of the Grand Cherokee..
Oddbob
Forum Member
Forum Member
Model and Year: 1995 854 Turbo
Postby Gubernaculum » 27 Jun 2012, 05:37
Oil pressure failed on me (volvo magic gasket sucked into strainer). So, pulled the pan and replaced the oil pan seals.
Also: PCV (currently in pieces), timing belt replacement, ABS module broke, and ETM sets off the ETS light at least half the time. Cruise control also just stopped working.
And a bunch of other little stuff. All in the first 1000 miles of ownership. Ouch. 98k miles. So far I've had all the classic big $$$ failures so hopefully from here on out I'll be alright.
Gubernaculum
Forum Member
Forum Member
Model and Year: '00 s70
Postby Veneficus » 28 Jul 2012, 12:30
Missing the convertible top closing mechanism ;)
Veneficus
Model and Year: C70, 1999
Postby dbjamin » 06 Oct 2012, 02:10
Tensioner. I'm on engine #2.
Recommend adding that part.
Thanks, Ben
1998 Volvo XC70 225K (second engine)
dbjamin
New Member
New Member
Model and Year: Volvo XC 70 1998
Postby sewsavannah » 19 Oct 2012, 02:19
sewsavannah
New Member
New Member
Model and Year: 1998
Postby Ben850 » 19 Oct 2012, 12:34
dbjamin wrote:Tensioner. I'm on engine #2.
If it was, I would add my vote as well.
I was driving for the last year with an unusual and abstract knocking noise from the front of the engine in the pulley areas. at first I imagined the serp belt was the culprit. After doing the timing belt and pulleys last week, I found the hydraulic tensioner was leaking after I compressed it, so the plastic clip on the tesioner likely saved my engine. The noise is now gone, and I believe the odd knocking was the tensioner pulley bouncing randomly.
By the way Matt, I can still not add to the list. You may have fixed it for everyone else, but since I voted before the fix, I guess I am out of luck. No big deal, I may chime in from time to time with a new failure.
1996 850 Turbo Wagon White.
Ben850
Forum Member
Forum Member
Model and Year: 1993 850 GLT White.
Postby rspi » 28 Oct 2012, 21:03
I actually have a door latch that has jammed and will not let the door open from the inside or out.
'95 855 T-5R, Panther - 21/27 mpg
'98 S70 GLT, Lil' Red
Volvo's of past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow
ABS Light? - My Volvo Video Channel
rspi
Senior Forum Member
Senior Forum Member
Model and Year: 850 T-5R Wagon
Postby rwc2117 » 06 Nov 2012, 20:50
2000 S70 (non-turbo) 142K .... just replaced radiator assy. (Small /slow leak bottom left corner of radiator ... had to refill coolant tank evry two weeks)
rwc2117
Model and Year: S70,2000
Postby Gubernaculum » 04 Jan 2013, 19:48
Adding some more to the list:
gas flap hinge
upper motor mount
ETM finally failed completely
center console cover and front seat covers both fell apart
door panels separating, and leather pulling away from elbow rest (how annoying)
one or two window switches
power seat won't go fwd/backward but other functions work (I suspect the switch)
antenna mast
thermostat
ignition switch cylinder requires the magic touch to turn
cup holder
spring seats
Coming soon:
turbo has tons of shaft play and may be the reason for my smoking problem (pcv job already done)
Gubernaculum
Forum Member
Forum Member
PreviousNext
Save thousands off MSRP on your new car.
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: Bing [Bot], gdog, Google [Bot], Google Adsense [Bot], iv46vi, j-dawg, mfagus, tomstir, tryingbe, turbos70t5 and 62 guests
