IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    ABS Module or Wheel Speed Sensor?
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby Slumbo555 » 25 May 2012, 20:21
    Hi. This is my first post, and please excuse me if I'm asking something that has been answered numerous times before. I have a '99 S70 GLT with the notorious ABS malfunction, giving me a P1550 (wheel speed sensor) code. From what I've read, the controller is almost always the culprit, but I just wanted to make sure before I spend any money.
    When the ABS unit goes bad, will the speedometer and odometer always malfuntion? I seem to have all of the symptoms except for that. My Cruise Control stops working, ABS and Traction lights come on, the transmission seems to shift differently, the RPMs take much longer to come back down... But I've also had the ABS kick in when it shouldn't, just under normal braking conditions, and I've heard this is more of a sensor issue, but I could definitely see that also being a controller issue. Thanks for any help!
    -Slumbo
    Reason: Edited title. Removed extra ? marks.
    -Slumbo
    1991 240, 209k
    1999 S70 GLT, 140k
    Slumbo555
    New Member
    New Member
    Model, Year: '91 240, '99 S70 GLT
    Re: ABS Module or Wheel Speed Sensor?
    Postby matthew1 » 25 May 2012, 21:31
    It's very rare that it's the wheel sensor. Matty Moo has done 700 ABS module rebuilds, and his prices start at $55.
    At that low of a price it's a good way to troubleshoot this, because if it's not the module, it will be soon.
    Please buy from MVS sponsors. It keeps this site on the web.
    Thanks for choosing this Volvo Forum to get your Volvo info.
    Like this spam-free, organized forum? Thank a moderator.
    1997 850 T5
    matthew1
    Site Admin
    Model, Year: 850 T5, 1997
    Postby Jot » 26 May 2012, 01:35
    1550 is a code for one of the front wheel sensors. I was able to use an ohm meter to find which one was bad. The wire harness can be unplugged and tested without removing the sensor . When I found the one with an open circuit I tied on a string before pulling it out from the bottom and used the string to pull in the new one.
    Jot
    Forum Member
    Forum Member
    Postby geokilla » 26 May 2012, 02:40
    I'm experiencing similar symptoms as well and I'm pretty sure it's an ABS Module problem. I'm going to order an ABS Module from Matty and hopefully everything works again.
    http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=48767
    2000 Volvo S70 SE; First Owner; 292k km :)
    2012 Volvo S60 T5 Level II; Lease; 32k km :D
    geokilla
    Forum Member
    Forum Member
    Model, Year: S70, 2000
    Postby Matty Moo » 26 May 2012, 02:59
    Jot wrote:1550 is a code for one of the front wheel sensors. I was able to use an ohm meter to find which one was bad. The wire harness can be unplugged and tested without removing the sensor . When I found the one with an open circuit I tied on a string before pulling it out from the bottom and used the string to pull in the new one.
    Kinda-sorta... P1550 is just a regular p-code that says the tcu isn't getting a valid speed signal from the abs module. The tcu tells the ecu to set the light, but to figure out which one it is you have to do either what you did or scan.
    matthew1 wrote:It's very rare that it's the wheel sensor. Matty Moo has done 700 ABS module rebuilds, and his prices start at $55.
    As of today I'm right around 2000 altogether. 1557 of them were exchange and somewhere around 400 were mail in repairs. There's a handful I did when I first started before I kept a yearly spreadsheet that aren't in there.
    The amazing thing is that 80% fo the people I deal with have zero idea about any of the Volvo forums or are enthusiasts.
    http://www.midwest-abs.com
    1996 850 Platinum Wagon. ARD Green Tune, OBX.
    1999 s70 Plain Jane.
    Matty Moo
    Senior Forum Member
    Senior Forum Member
    Model, Year: 850, 1996
    Postby Slumbo555 » 26 May 2012, 20:37
    I'll be ordering an ABS module today after I doublecheck the part numbers to make sure I'm ordering the correct one. Hopefully I can get this taken care of and move on to the next issue...
    Thanks for the advice!
    -Slumbo
    1991 240, 209k
    1999 S70 GLT, 140k
    Slumbo555
    New Member
    New Member
    Postby Slumbo555 » 02 Jun 2012, 02:22
    I installed my rebuilt Midwest ABS module a couple days ago and so far do good! I haven't put very many miles on the car since the install (due to another car issue that was resolved today), but I feel pretty good about the fix. Thanks for the advice everyone.
    -Slumbo
    1991 240, 209k
    1999 S70 GLT, 140k
    Slumbo555
    New Member
    New Member
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: Ben850, jimmy57 and 124 guests
