1998 S70 Have spark, fuel pump power, no fuel
joe gill
Year and Model: S70 1998
Postby joe gill » Mon Aug 20, 2012 5:10 am
:? "felt like it was running out of gas replace fuel pump, fuel relay has spark from coil and to spark plugs wont start just cranks pulled off fuel line crank mtr over for 40 sec no gas comes out, when the key is on number 2 position pump hums for few seconds so I have power to the pump
Reason: Please -- no ALL CAPS titles. Thank you.
rspi
Flag: United States of America
Re: 1998 S70 HELP WONT START
Postby rspi » Mon Aug 20, 2012 2:24 pm
Hey Joe, don't really understand what you say you did. Did you check for fuel pressure at the end of the rail near the throttle body? It is possible for the fuel pump to run and not put out pressure. Did you replace the pump? Maybe a line came loose in the tank. Try to start the car then pull the fuel line off the filter and see if any fuel comes out there.
'95 855 T-5R, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red
Volvo's of past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow
Donate Today - Volvo Repair Videos
joe gill
Postby joe gill » Mon Aug 20, 2012 5:45 pm
rspi wrote:Hey Joe, don't really understand what you say you did. Did you check for fuel pressure at the end of the rail near the throttle body? It is possible for the fuel pump to run and not put out pressure. Did you replace the pump? Maybe a line came loose in the tank. Try to start the car then pull the fuel line off the filter and see if any fuel comes out there.
If you reread post i replace the pump and relay pull off fuel line at filter crank for 30 seconds no gas
Year and Model: 1998 S70 GLT
Re: 1998 S70 Have spark, fuel pump power, no fuel
Postby cn90 » Mon Aug 20, 2012 6:10 pm
- Jump terminals 15 and 87 on the fuel relay socket.
If fuel pump runs, car should start.
- If not, then check voltage at terminal 15, with key in position II, you should have 12V there.
If not check ignition switch/wiring etc.
1998 S70 GLT 160K+
2005 XC90 2.5T 85K+
jimmy57
Postby jimmy57 » Mon Aug 20, 2012 6:13 pm
If the wires on fuel pump are reversed it will run and not pump fuel
joe gill
Postby joe gill » Tue Aug 21, 2012 5:31 am
Jimmy your right i reverse earlier today and aftermarket wires on new pump were missed labeled i change to red on black reinstall pump works
rspi
Postby rspi » Tue Aug 21, 2012 2:02 pm
So, the car runs now?
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Baidu [Spider], Bing [Bot], ktuuri, netghost, Sommerfeldt, Teddy1975, Yahoo [Bot] and 48 guests
