My 1998 Volvo S70 non turbo will not start.
jimmy57
Re: My 1998 Volvo S70 non turbo will not start.
Postby jimmy57 » Wed Jun 19, 2013 7:09 pm
WHen it turns over does it sound like it is spinning REALLY fast or is there a normal cyclic noise like is normal while engine is cranking?
I am asking because I am suspicious of hanging valves and extended tappets (lifters) that are common to this engine family through 1999.
If it is cranking fast then hold accel pedal to floor and crank it over for a minute. THen do that again. Often it takes 2 plus minutes for the engine to start when it has the sticking valve issue. You must have a good fully charged battery to crank it over that long. DO not stop until you reach a minute. Every time you turn to start position a cranking enrichment occurs. 1 minute does not mean 15 secons 4 times, it is 1 minute continuous.
jpr0204
Year and Model: 00' V70 X/C SE
Postby jpr0204 » Wed Jun 19, 2013 9:27 pm
Jimmy57,
1 minute of continuous cranking will have the starter motor glowing red and may shorten it's life dramatically no?
To each their own, but I personally wouldn't lay on a starter for a full 60 seconds.
What if you pour a gallon or two of fuel in and shoot just a quick spray or two of starting fluid in the intake and then give it try? May the ether will help it along just enough to get it going?
- Joe
- Joe
Current Vehicles:
00' Volvo V70 X/C SE (girlfriend's car) Currently at 112K miles
12' Yamaha V-Star 950 EFI Tourer (My daily summer crusier) Currently at 7K miles
95' GMC Yukon SLT 4x4 4-Door 5.7L 350 V-8 Currently at 120K miles
m96ag
Year and Model: 2000 V70XC
Flag: United States of America
Postby m96ag » Wed Jun 19, 2013 9:57 pm
Personally, it sounds odd, but if this were true starting fluid would not help because there would be no compression from the valves being stuck open. Although, if there were no compression the load on the starter motor would be minimal.
2000 V70XC 158,600mi.
robertcnorman
Year and Model: S70, 1998
Postby robertcnorman » Wed Jun 19, 2013 10:08 pm
Ok. I just put gas in and turned it over twice. It still is not starting. I do hear a normal hum (Hopefully from the fuel pump) before I turn it over and it holds steady for at least a few minutes when I decide to turn the key. It sounds like it wants to start but just doesnt.
m96ag
Postby m96ag » Wed Jun 19, 2013 10:12 pm
Try following this video to jumper the fuel pump. It should only run for a few seconds if the engine isn't cranking or running. http://youtu.be/GclQq7VpC08
robertcnorman
Postby robertcnorman » Wed Jun 19, 2013 10:25 pm
It does not sound abnormal (Or like its spinning) when I turn it over.
robertcnorman
Postby robertcnorman » Wed Jun 19, 2013 10:34 pm
I can try that. Thanks.
robertcnorman
Postby robertcnorman » Wed Jun 19, 2013 11:24 pm
Tried the Relay jump start and there was no difference.
m96ag
Postby m96ag » Wed Jun 19, 2013 11:30 pm
Have you checked the fuses for the fuel injection?
robertcnorman
Postby robertcnorman » Wed Jun 19, 2013 11:41 pm
I checked all the fuses and they look good.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Jazzop, rguzz and 36 guests
