How to read your actual miles from the ECU
lovl850
Year and Model: 850 GLT, 1993
Re: How to read your actual miles from the ECU
Postby lovl850 » Fri May 06, 2011 1:52 am
Update: I had to clear a code on the A2 socket before reading again. The ECU now reads 168,808 miles and I have 168,817 on the odometer, that's close enough! :)
maverickbna
Year and Model: 1996 850
Postby maverickbna » Fri Jun 03, 2011 4:02 pm
Is there any way to get the actual mileage from an OBD-II ECU? I have a '96 850 base model, and the odometer's stuck at 51,723. I just got stuck with a 'not actual' branded title, and now that I know that it's a broken odometer gear, I'd like to get my local Volvo repair shop to get it fixed!
I wouldn't mind repairing other stuff, but this sounds a little too complicated to do the odometer repair!
Swedish Chef
Year and Model: 850 1995
Postby Swedish Chef » Fri Jun 03, 2011 4:09 pm
Here's the lnk to retrieving the milage: http://www.brickboard.com/AWD/index.htm?id=680941
I just did it on my '95 obdII so it should work on your '96. good luck!
OOOPS i just noticed its the same as the first thread!
Rudyp213
Year and Model: 850 94'
Postby Rudyp213 » Sat Aug 06, 2011 6:39 pm
Where can i get the Wire that plugs into A7, And where exactly is A7?
Year and Model: Many Volvos
Flag: United States of America
Postby Ozark Lee » Sat Aug 06, 2011 7:17 pm
Welcome to MVS,
The flywire came with the car and the DTC boxes are located just behind the windshield washer fluid filler.
This is specific to port A-2 but it is all the same for the other ports. Once you remove the cover you will see the numbers.
http://volvospeed.com/CheckEngine.php
'98 S70 T5
'99 V70XC - RIP - Wrecked Parts Car.
'99 V70XC - Nautic Blue
'96 850 N/A
850James23
Year and Model: 850 Turbo, 1994
Postby 850James23 » Fri Sep 30, 2011 4:07 am
More info on getting the mileage for an 850 (mine '94). 2 small covered connector boxes between the washer fluid port and the hood latch. Remove cover to the left box (A), I used a flathead screwdriver from the top, between the boxes, to loosen the clip for the cover. The Flywire is attached to the connector and its metal tip is held in the cover. Pull tip out of the cover and insert into A2 to read codes, A7 for mileage. I plugged wire in, then turned ignition on (to position II), read codes, cleared them, turned ignition off, plugged in to A7, ignition on, read mileage as described.
DO IT, it is VERY easy and so helpful! Odometer broke at 133004 3 years ago and I finally found the energy to fix it, 185,216!. P.N. 13800 from IPD is a little plastic gear ($30) to replace in the back of the instrument pod - also easy, IPD includes DVD with great instructions.
jtwerp
Year and Model: 850 Turbo Wagon
Postby jtwerp » Sat Oct 01, 2011 5:15 pm
Should the fly wire, have a solid end on it? Mine is a frayed wire, it should still work, right? This is on a 95 850 turbo wagon.
Postby Ozark Lee » Sat Oct 01, 2011 6:07 pm
Most of the flywires have the frayed insulation but so long as the wire is still hooked up to the plug it should work. Be gentle with it.
'98 S70 T5
'96 850 N/A
tjts1
Year and Model: 96 855 NA 5 speed
Postby tjts1 » Sat Oct 01, 2011 10:55 pm
maverickbna wrote:Is there any way to get the actual mileage from an OBD-II ECU? I have a '96 850 base model, and the odometer's stuck at 51,723. I just got stuck with a 'not actual' branded title, and now that I know that it's a broken odometer gear, I'd like to get my local Volvo repair shop to get it fixed!
I may have something on that in the next few days.
Ambitious but rubbish
petek153
Year and Model: 1992 940T
Postby petek153 » Sun Oct 02, 2011 2:37 am
On 1995 and earlier, you can read the ECU mileage from the diagnostic port as follows:
1. Select module A terminal 7
2. Switch ignition on
3. Push button 5 times
4. When LED comes on and stays on, enter code 1-1-1 as follows:
- press the button once when LED is still on
- wait for LED to go out and come on again
- read off response, which will be the last three digits of the odometer miles
5. Repeat steps #3-4, but enter code 1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles. If you have less than 100,000 miles, the first digit will read as 10 blinks.
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: 1997volvo850, 98v70dad, Blockpartie, jonnycycles, PS78, Sommerfeldt, tryingbe and 42 guests
