Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
by bobsnow100 » 15 Aug 2006, 20:52
I have a 1994 850 wagon. I am in the middle of changing a head gasket. My question is in regards to the cam cover. I have improvised the tools to hold the cams locked in the cam cover.
My first question is in regards to the liquid gasket compound that gets rolled onto the cam cover.
1. Do I install the cover with the liquid gasket compound wet or let it dry?
2. Do I have to get the special volvo roller or can it just be brushed on thin with a small brush?
Thanks
bobsnow100
- Forum Member
by Ripper406 » 16 Aug 2006, 01:38
I just recently changed the head gasket aswell, make sure you get the cylinder head resurfaced. About the cam cover, I just used some copper gasket spray and put the cams on the head first, then put the cover on. I saw the book says the other way around but it seemed like too much work to hold them inplace on the cover then bolt it down.
Now the problem is their is no engine rpm signal coming to the ecu so its being shady and not firing off the injectors. I cannot find where the rpm signal source comes from, im thinking the Cam Position sensor but I doubt it, I would have gotten a CPS code.
I have a 1994 Volvo 850, changed the head gasket and now the fuel injectors dont fire off, sparks good but no fuel.
Ripper406
- New Member
by MadeInJapan » 16 Aug 2006, 01:51
Ripper, download the service manual for your car- first post in the sticky. It's all in there...diagrams, etc.
94 850 Sedan NA Drk Blue/Tan
'00 V40 Purple/Grey Mobil-1
- Model, Year: '98 S70 T5
by White850Turbo » 16 Aug 2006, 04:38
bobsnow, the liquid gasket can be applied with a small brush in a thin layer. Don't let it dry before placing the pieces back together.
Ripper, RPM sensor is located on the transmission housing. It's the one more towards the top and middle. The vehicle speed sensor is the one that looks similar, but is located further back.
-Sean
1998 S70 T5 (Almost Stock)
White850Turbo
- Forum Member
by bobsnow100 » 16 Aug 2006, 14:15
Thanks all, I can now know I'm doing it correctly
bobsnow100
- Forum Member
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: Bing [Bot], fn42, Google Adsense [Bot], Matty Moo, rmmagow, taupehat and 156 guests
