Driver side - heated seat not working
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
trstjohn
Year and Model: 07 XC90
Postby trstjohn » Sun Feb 06, 2011 1:26 pm
All--
I've noticed my driver side heated seat is not warming up at all.. I investigated under the seat and it looks like everything is hooked up. The passenger seat heated module does work.
On another note, I'm not sure if it's related, but since my CD player is shot and I'm getting the SRS Airbag maintenance message, does this have something to do with it since a variety of components are ran under the driver seat?
Any suggestions on troubleshooting this issue?
2003 Volvo XC90 T6
2007 Volvo XC90 3.2 (Wifey)
dyerkes
Year and Model: 2003 XC90, 2010 S80
Re: Driver side - heated seat not working
Postby dyerkes » Tue Feb 08, 2011 3:13 am
I'm guessing that it's likely the heating element on your seat, as that is what happened with mine. It wasn't working when I purchased it, and after trying to switch it on several times I noticed that it got painfully hot in one spot. When I stopped the car to see what was going on I found a small hole in the leather that was burnt. When I removed the leather from the cushion I found that one of the electrical heating element wires had broken (looked a little rusty).
With regards to your SRS light, if anybody had removed and unplugged your entertainment console without first having disconnected your battery, than that may be the issue.
Regards,
David
jimmy57
Postby jimmy57 » Tue Feb 08, 2011 5:07 am
The CD probably has no bearing on seat problem but the gang connector under seat not being securely latched together could give seat heater and SRS problems.
trstjohn
Postby trstjohn » Tue Feb 08, 2011 7:43 pm
All of the cords are connected correctly in the front; however I did notice that two connectors were not plugged in when I initially bought the car (grey and green). I connected the grey but the seat is still not heating up and green to no avail. Due to the awkward position, I'm not able to see where the green should be plugged into.
Is there a diagram I can reference to make sure i'm plugging everything in the correct slots?
2003 Volvo XC90 T6
TexasCoder
Year and Model: 2004 XC90 T5 AW Tran
Postby TexasCoder » Fri Feb 11, 2011 12:04 pm
Look at the attached document for Seat repair. This should help, I suspect it is your heater pad that is malfunctioning. I haven't looked, but I am certain I remember seeing replacement pads on FCP Groton. Let us what you find!
Seat_And_Heater.pdf
(1.14 MiB) Downloaded 2378 times
dougbrewster
Year and Model: S60 T5 2001
Postby dougbrewster » Fri Mar 01, 2013 9:03 pm
I've just got my heated seat working on the first day of Spring. The heater elements had checked out OK - 0.8 ohm for the seat pad and 0.4 ohm for the backrest - as near as you can tell with a good multimeter and allowing for the lead resistance. Power was available at the black and red connector on the seat heating module under the seat so I bought a second hand module from a breaker on ebay for £13.50 and it fixed the problem.
It was difficult to replace the seat heating module with the seat still installed; you need to be very dexterous to get to the torx screw holding the module itself and the two 10mm bolts holding the audio amp on the floor which needs to be moved out of the way to get to the screw holding the seat heating module.
I had bought a Haynes manual for wiring information but it was only marginally helpful - no wiring colour codes or other useful details but the schematic arrangement was somewhat helpful in that it identified that there was only one stat (in the seat pad) and it was logical therefore to suppose that the two elements are connected in series - hence the 0.8 ohm plus 0.4 ohm = 1.2 ohm on a 12 volt supply = 10A current draw. This matched with fusing at 15A per seat. The series connection of the heating elements must be in the heating module because it isn't in the wiring.
It is very easy to disturb the connections for the seat airbags when working upside down under the seat so be sure to disconnect the battery first.
Return to “Volvo XC90 Forum”
Who is online
Users browsing this forum: No registered users and 7 guests
