IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    Driver's Side AC blows warm, psngr side cools fine
    Help and Advice on S80 Volvo cars.
    Postby LovemyS80 » 28 May 2011, 21:48
    Driver's Side AC blows warm air, passenger side is still cooling fine. Fan is not affected. Would love to know how to fix this. Seems to be involving a valve that is just not opening on the driver's side of the dual climate control system. Anybody have any ideas on what the fix is here?
    LovemyS80
    Model, Year: 2006 S80
    Re: Driver's Side AC blows warm, psngr side cools fine
    Postby jimmy57 » 29 May 2011, 01:25
    My suspicion is low refrigerant as this is common on P2 Volvos to have the driver's side warm up if the refrigerant is low.
    Quicke check for low charge is to run engine at a high idle (1200-1500 rpm) for a few minutes. I have a mailer tube I put on accel pedal and run the power seat forward to hold my throttle. A wooden dowel or old broom handle cut to the proper length also works. After a few minutes find the larger a/c pipe that comes out of center of firewall. It should be cold. If not it is low on refrigerant.
    If the line is icy cold then check for the servos that move the doors in climte system to regulate temp not functioning right.
    Turn the driver's side temp to to full hot till knob stops , wait a couple of minutes and then turn it to full cold. Do this with engine running and fan on in middle position. Listen and feel for air temp changes and for the sound to change, repeat for the passenger side.
    The 2005 and up volvos damper control system can get confused and full travel commanded through full hot to full cold end points may reset it.
    If you can't get resolution then it is time to go to a shop that has VIDA or other scan tool that can do COMPLETE vehicle.
    jimmy57
    Senior Forum Member
    Senior Forum Member
    Model, Year: 2004 V70R GT, et al
    Return to Volvo S80 Forum
    Who is online
    Users browsing this forum: No registered users and 23 guests
