Timing belt replacement on 1999 S80
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
mikeyfood
Year and Model: S80, 1999
Postby mikeyfood » Mon Sep 19, 2011 10:33 pm
Dealer is recommending I replace the timing belt, drive belt and tensioner. $375 for parts and total $1000! How hard is it do it yourself and how can I find out how?
retcoastie
Year and Model: S80 1999
Re: Timing belt replacement on 1999 S80
Postby retcoastie » Mon Oct 31, 2011 6:47 pm
I recently replaced the water pump in a T6. I took the timing belt off in order to do it. I had to come at it from the front wheel well. I removed the inner fender. That and moving the coolant and power steering tanks allowed about 2 inches of working room. Make sure you can locate the cam and crankshaft positions. I marked them with a grease pencil and in doing the work almost rubbed off the mark on the rear cam. Make your marks by scratching the gears!!!!!!!! I think I would count the belt teeth between the marks also to insure alignment.
I reset the tension piston by putting it in a vise and very slowly compressing it. It has a very small hole for the hydraulic fluid to pass through so be patient. Make sure the pin you put in is stronger enough. Wait awhile before reinstalling so that if the pin bends you can correct it on the bench, not in the 2" space in the car. :)
Good Luck
Ken
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Postby boosted5cyl » Mon Oct 31, 2011 9:21 pm
It's a little trickier than your typical timing belt job as you dont have a lot of room to work and the VVT pulley on the exhaust cam can cause people headaches if they dont lock the cams at the back of the head. To make it easy on yourself you should look into getting the cam lock tool.
Unless you know with 100% certainty when the parts were last done, I would do everything. By that I mean hydrualic dampener, pulleys and water pump. You could do the cam oil seals too, however this can be tricky without the cam lock tool.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
UncleBoost
Year and Model: 855 R, 1996
Postby UncleBoost » Sun Nov 20, 2011 8:26 pm
I too am faced with this delimna. Head is Done, back on and torqued down....now comes the confusing part Installing the Cams, finding what cylinder is should be where...I put the engine @TDC, which I read thats where it should be, and I also read it's not... can someone clarify please!!!!??.. I can see the mark on the Crank mount where the large plate bolts to. This mark is nowhere near TDC for Cyl 1. Am I correct in saying Lining the Crank with the vertical Hash, and Locking the Camshafts with a Lock tool, Will this be the correct way to BEGIN the belt placement? Does the Lining of crank mark, and the locking of the cams take the complication out of the equation as far as MECHANICALLY Not having to be TDC? Does this mean theoretically if the belt were on, and 2 complete revs by hand of the crank there would be no interference? Or do I need to go thru that treacherous procedure for VVT Cam installation?.. Please Help!! Stuck at this point.. The various write ups I've seen seem to be contradictory in critical areas...What the Official procedure for the 2000 S80 T6 Twin turbo with VVT? VVT is on the Exhaust Cam...I can supply photos if needed... I have the engine at TDC, the mark on the Crank is about @ the 2 oclock position...
boosted5cyl
Postby boosted5cyl » Sun Nov 20, 2011 8:37 pm
Basically you can forget about TDC, its not relevant for your motor. When the marks line up on the crank pulley and oil pump, you will not be at TDC. This is normal. Whats relevant is that everything is on its appropriate marks when you start putting the belt on.
My recommendation would be to remove the starter motor, pull the allen plug behind it and drop a 3/8" extension into the hole to ensure you are lined up on the crank and more importantly, that you stay there.
In terms of setting the VVT, the end goal is to have the inner hub fully tensioned (turned clockwise) when the marks on the crank, cams and cam pulleys line up.
UncleBoost
Postby UncleBoost » Sun Nov 20, 2011 9:39 pm
Now after 2 weeks of reading over various posts, procedures, this is the ABSOLUTE BEST explanation I've read.!!! When I get home I'll post Fotos of what have so far. This is like finding a UFO crashed in the back yard....and a schematic to the ship! I'll be in touch in a few hours... Thanks!
boosted5cyl
Postby boosted5cyl » Sun Nov 20, 2011 10:15 pm
Yeah its one of those concepts that easy in principle, but can be hard to describe. Post back if you have issues.
UncleBoost
Postby UncleBoost » Sun Nov 20, 2011 11:53 pm
Here are some photos of where I am in this task.
Asking, IS this where I need to Align the Green mark with the Red Reference?
INTAKE Cam....With the Cam installed in the head, Should the OFFSET Slash be Below or Above the Centerline?
Where should the EXHAUST Slash Be Below or Above Centerline?
I will post pictures later of the Cam shaft Gears. The Intake cam gear was removed from the Camshaft BEFORE I bought the car. The V V T Camshaft is still in Tact. I looked at BOTH gears and found the FACTORY Marks for both COGS...Are the factory marks on the Cogs the reference to marks that line up with the cutouts in the Plastic Timing Backplate?
Thanks
UncleBoost
Postby UncleBoost » Tue Dec 13, 2011 9:55 pm
boosted5cyl wrote:Basically you can forget about TDC, its not relevant for your motor. When the marks line up on the crank pulley and oil pump, you will not be at TDC. This is normal. Whats relevant is that everything is on its appropriate marks when you start putting the belt on.
Ok so looking at my Diagram, when I 1st install the cams, Locked, Cranked mark lined up, Crank Locked with extension, I install the V V T hub/gear (gear with the 3 bolts lightly snugged full left) 1.5 teeth away from Timing mark, no tension on the hub yet and Center Bolt snugged. When I turn the gear AGAINST the spring until it stops or bottoms out, (Timing mark on gear should line up Dead Nuts with the timing cover reference) IS THAT where I torque the V V T center bolt to 120nm? Will the hub spring back when I let the gear go? Or will the gear stay lined up with the mark? This is where I get confused...
Thanks for you help.
UncleBoost
Postby UncleBoost » Tue Dec 13, 2011 9:57 pm
..so basically keep "Easter egging" the hub position to achieve LINED UP MARKS with bolt Fully Torqued to 120nm?
Return to “Volvo S80 Forum”
Who is online
Users browsing this forum: Sm8yT6 and 11 guests
