How to clear the Emission System Service Required warning.
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
esb
Postby esb » Sun Dec 03, 2006 8:34 pm
I recently changed the spark plugs in my 1999 2.4L 170hp non turbo S80. A few hundred miles later the Emission System Service Required warning message was displayed along with the amber engine warning light.
The car is operating well and fuel consumption has improved since changing the plugs. Does anyone know how to cancel the warning messages, as I believe they are spurious. Tried the Service reset procedure, but this doesn't work for Emission light. I heard that disconnecting the battery for 20 minutes or so may do the trick, but am a bit dubious that this will help and haven't tried that yet. The car has covered 150 000 trouble free miles.
Thank you.
Year and Model: '98 S70 T5
Flag: United States of America
Postby MadeInJapan » Sun Dec 03, 2006 9:46 pm
Before blindly resettting the light, read your codes in case there is some type of major problem. You'll need a scan tool. Most any should work for what's coming up. AutoZone or just about any auto parts store should be able to do it for you. If they'll read your codes but not reset them (some will be sticklers about this...they don't want to be responsible for any damage), then you can "rent" one from them...put down the cost of buying one which you'll get back when you return their scan tool to them.
Post up the codes you get ones you read them.
esb
Postby esb » Sun Dec 03, 2006 10:30 pm
Thanks for your advice. I'll try to get the codes first as you suggest. But having found the codes, how do I reset the warnings? Do I need a dedicated reset tool or can it be done without any extra equipment?
Postby MadeInJapan » Sun Dec 03, 2006 10:48 pm
Some Volvo codes can't be reset...usually the Air bag (SRS) AC, etc.- things that are Volvo specific. However, the main stuff...engine management, transmission, ignition, etc. can be reset by hitting the "erase codes" button on most any scanner. Good luck and let us know how it worked out.
esb
Postby esb » Mon Dec 04, 2006 9:01 pm
OK, thanks. I'll llet you know how I get on.
esb
Postby esb » Wed Jan 31, 2007 10:44 pm
Thanks again for the info and advice. Codes indicate oxygen sensor which I'll get changed. I would have expected fuel consumption to have increased with u/s O2 sensor, but although consumption ok, emissions will prob be too high, so worth changing. Now on the look out for a sensor I can afford.
Eric
Return to “Volvo S80 Forum”
Who is online
Users browsing this forum: No registered users and 3 guests
