IPDVolvo PartsVolvo Salvage: Used Volvo Parts and Over 50 Years ExperienceSouthern Vo Vo sells genuine used Volvo parts
Volvo Parts
Buying gifts? Please use this Amazon link ... and help keep MVS on the Web. Thank you!Amazon.com
MVS Login
Register - it's Free!
Get Help
Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
Volvo Parts
Shopping Amazon.com? Help MVS by using this link!
Febi-Bilstein Spring Seat only lasted 50K
Volvo Parts talk... Which brands are bad, which are good? What Volvo part NEEDS to be OEM? What can we "cheat" on to save some money? OEM = "Original Equipment Manufacturer".
Postby C@lvin » 20 Jul 2011, 17:34
Installed on passenger side of a 98 S70 at 160K and failed at about 210K.
I got it for its mid level price point and I considered them a reputable manufacturer.
This result appears to support the oft repeated mantra to stick to Volvo OEM spring seats.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
C@lvin
Forum Member
Forum Member
Re: Febi-Bilstein Spring Seat only lasted 50K
Postby ChiNorm » 26 Jul 2011, 19:30
You are lucky, I had a hard time getting a year from those (OEM) things in pot hole laden Chicago. Either use the XC90 part or else get the IPD HD versions. The last much longer.
ChiNorm
Forum Member
Forum Member
RETRACTION/APOLOGY Febi-Bilstein Spring Seat only lasted 50K
Postby C@lvin » 28 Nov 2011, 17:12
My apologies to Febi-Bilstein! :oops:
I replaced my struts last week (98 S70 NA 218K) and I purchased a new Boge (Volvo) spring seat to install on one side because the top strut nut was spinning for about the last 8K miles and I assumed the Febi spring seat I previously installed had failed.
I discovered that the spring seat is just fine and actually looked to be in very good condition. The reason the top nut was spinning is that the cross shaped nut that goes on top of the spring seat had become loose.
The Febi-Bilstein spring seat is made in Germany, looks to be solidly contructed and (contrary to what I had thought) is still going strong at 58K miles.
Calvin
98 S70
00 V70
C@lvin
Forum Member
Forum Member
Save thousands off MSRP on your new car.
Return to Volvo Parts
Who is online
Users browsing this forum: No registered users and 1 guest
