IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    2001 Volvo S40 Turbo MAF Replaced Doesn't fix stalling
    Help and Advice on S40, V40 and V50. In this forum you'll find S40/V40/V50-specific owners asking and answering questions on maintenance, ownership, repairs, tutorials and almost every do-it-yourself thing you can do to save money owning these Volvos.
    1996 - 2004 S40
    1996 - 2004 V40
    2004 - 2004 V50
    Postby ferejohn1 » 07 Oct 2009, 13:12
    I brought my volvo to my mechanic, said the MAF needed replacing. Car will stall, rpms fall below 1000 when stopped. Need to give the car gas when starting, seems to run smoothly when foot on gas but as soon as you let up it stalls. He replaced the MAF, but this did not help. Said the code is still there, may be electrical problem and I should take to the dealer. Don't want to do that, any ideas? Thanks for any help. Beth
    ferejohn1
    New Member
    New Member
    Model, Year: 2001 Volvo S40 Turbo
    Re: 2001 Volvo S40 Turbo MAF Replaced Doesn't fix stalling
    Postby billofdurham » 07 Oct 2009, 19:26
    To complete the repair the code must be erased. Does your mechanic have a code reader?
    Bill.
    Previously:
    1984 244DL, Manual, Beige.
    1987 744GLE, Manual, Green.
    billofdurham
    Model, Year: 855, 1995
    Postby ferejohn1 » 07 Oct 2009, 19:58
    He said the code kicked back on
    ferejohn1
    New Member
    New Member
    Postby billofdurham » 07 Oct 2009, 22:57
    Then it is possible the MAF wasn't the problem. Did he tell you what the code number was or can you find out?
    Bill.
    Previously:
    billofdurham
    Postby ferejohn1 » 07 Oct 2009, 23:14
    He said it was the MAF code. He didn't say what number. I spoke to him and I am taking it to the local Volvo dealership. He said it is easy for them to swap out electronic parts. I will let you know what they say. Thanks for your help. Hopefully it won't cost me a fortune. Beth
    ferejohn1
    New Member
    New Member
    Postby OEMVolvoParts » 08 Oct 2009, 18:34
    I'm gonna take a guess here. From what you describe sounds like your idle air control slide has failed. This is what controls then engine when your foot is off the pedal, which sounds right because you say it runs fine when you are on the gas. Part number is 8670419 and the gasket is 9470027. Please re-post what the problem was when you get it figured out!
    http://www.MyVolvoPartsOnline.com
    Your online source for genuine Volvo parts and accessories.
    OEMVolvoParts
    Forum Member
    Forum Member
    Model, Year: ALL
    Postby ferejohn1 » 10 Oct 2009, 01:01
    I got word today that the idle air control is stuck and the fuel pressure regulator was leaking. They are going to clean the throttle body while they have it apart and replace those parts. They think that should fix it. One good thing, they found out the catalytic converter has a crack and is under warranty - free fix. yay!!! I will keep you posted when I get it back. Thanks for your help. Beth
    ferejohn1
    New Member
    New Member
    Postby OEMVolvoParts » 10 Oct 2009, 17:13
    :P
    OEMVolvoParts
    Forum Member
    Forum Member
    Model, Year: ALL
    Postby ferejohn1 » 12 Oct 2009, 22:23
    It is fixed, and they replaced the catalytic converter and replaced a part for the climate control that was part of a recall! All done for $700.00 plus tax. Picking the car up tonight. Thanks I will keep this in my favorites! Beth
    ferejohn1
    New Member
    New Member
    Postby drvolvo » 13 Nov 2009, 00:39
    I had a very similar sounding problem and it was my rear booster sensor. If you still have problems (let's hope you don't) you can always ask to have that checked. There are front and rear booster sensors, fyi.
    drvolvo
    Forum Member
    Forum Member
    Model, Year: S40
    Postby ferejohn1 » 13 Nov 2009, 13:51
    Are you talking about the oxygen sensors, if so they were both replaced not that long ago, but as a follow up to my previous issue, the day before yesterday took out the Volvo to pick up my sisters, car started to hesitate and I could smell gas. Went right home only drove about 2 miles total. White smoke was coming out from under the hood. Popped the hood and a waterfall of gas was dripping from the pad the covers the inside of the hood. Very afraid it was going to go up in flames. When my daughter came home I had her look at the engine and I turned the key. Gas was shooting out about 2 feet into the air from the newly installed Fuel Pressure Regulator. Had the car towed back to the dealer and they replaced the part and I had them replace the liner inside the hood, because it was saturated with gas. Picked up last night and looked at gas gauge, car was on empty. I had filled the car up the morning of the incident. 10 gallons of gas gone! I am billing the dealer for this and the tow cost to me, (used my AAA but they charge for extra mileage) They never said exactly what went wrong with the first regulator they installed. Hope this is the end of this. Thanks. Beth
    ferejohn1
    New Member
    New Member
    Postby ferejohn1 » 13 Nov 2009, 14:06
    Just one more thing. Initial repair was done about 28 days ago, drove car a total of 113 miles before this leak happened. Thanks Beth
    ferejohn1
    New Member
    New Member
    Return to Volvo S40, V40 and V50 Forum
    Who is online
    Users browsing this forum: No registered users and 27 guests
