2001 V70 T5 - bad motor mount? other?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
gthrash
Postby gthrash » Sun Nov 11, 2007 1:16 am
Hi Everyone -
I've got an issue with my 2001 V70 T5. It's a bit strange, because I'm not consistently hearing a noise, rather when I accelerate, decelerate, or move the transmission from R to D or vice versa, I can feel a popping through the steering wheel. It seems to be related to the motor moving, and it's pretty consistent- If I'm on the freeway and accelerate or decelerate, I can feel it.
I have jacked up the two front corners and I can't visually see anything wrong.. my first thought is a bad motor mount. The top mount looks okay, but I'm not exactly sure where to look for the others? I also read something about a steering column bushing problem with older cars? This seems like a possibility?
I'd appreciate any insight!
Thanks,
Greg
Arbelac
Postby Arbelac » Sun Nov 11, 2007 2:00 am
Could be the tranny mount as well. Check the firewall end of the torque arm for wear on that mount.
-1998 V70 Cross Country Wagon, B5254T, AWD, 231000KM
- 2001 V70 T5M, FWD, 205000KM, QBM Strut Brace Conversion, QBM Poly Lower Transmission Mount, HD Endlinks
Flag: United States of America
Postby MadeInJapan » Sun Nov 11, 2007 2:38 am
Could also be the shift linkage. But check the lower engine/tranny mount. If I recall, on P2's there is no firewall mount on the end of the torque arm...the circular mounting bracket attaches to the cross bar....or is this only on our '04 V70?
Arbelac
Postby Arbelac » Sun Nov 11, 2007 4:20 am
MadeInJapan wrote:Could also be the shift linkage. But check the lower engine/tranny mount. If I recall, on P2's there is no firewall mount on the end of the torque arm...the circular mounting bracket attaches to the cross bar....or is this only on our '04 V70?
You're right, I forgot that... :duh:
gthrash
Postby gthrash » Mon Nov 12, 2007 5:12 am
Thanks for the suggestions, guys. I may pull the torque arm assembly apart, just because it's the only thing I can really locate and access easily!
I'm probably going to have to bite the bullet and take the thing to someone. Ah well!
Return to “Volvo V70 & XC-70 (2001-2007), S60 (2001-2009)”
Who is online
Users browsing this forum: keaunym, Luciendar21 and 37 guests
