2002 Volvo S60 engine suddenly cuts off
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 XC-70
jaxbomber
Year and Model: S60 2003
Re: 2002 Volvo S60 engine suddenly cuts off
Postby jaxbomber » Mon Mar 22, 2010 12:43 am
I used the process of elimination and started with the cleaning of the throttle body. The mechanic I used said there was a lot of trash accumulation. He cleaned the throttle and I haven't had a problem since then. Cost me $175 to do something I could have done but I'm just glad that the most annoying driving experience I've ever had is over.
VOLVO20T
Year and Model: 2001
Postby VOLVO20T » Tue Sep 18, 2012 10:19 am
Hi guys i have a Volvo S60 2.0 TURBO 2001 i had a problem witch seems to be same as yours problems on Volvo's i have a good news for u guys don't worry about the car everything is fine is not the engine its the EMT i had it cleaned and it does not cut's off now BUT the rews are going up and down i have took it to the motorway and give it fast ride take it to 130mph a have did it and my Volvo is in perfect condition, to clean the EMT it cost my £50 witch is nothing hope this will solve your problem....
BIG THANKS TO AUTO DIRECT GARAGE IN BIRMINGHAM HANDSWORTH
zuma6195
Year and Model: S60 2005
Postby zuma6195 » Wed May 06, 2015 5:16 pm
I have a 2005 volvo S60. It runs great and smooth and has 143000 miles on it. One night as i turned the corner, it stalls. No check engine light...nothing. It starts right back up afterward. After some intense research and according to "justnaswer.com", it could be the crankshaft position senor ($ 40) . I will change it today and will come back to let everyone knows what happened.
marshg2k
Year and Model: S60 2002
Postby marshg2k » Thu May 07, 2015 12:31 am
I found my issue was actually really simple. I had to clean the throttle ... This issue for me had to do with idling. So when I slowed down at a corner the engine would cutoff. The bad idling was a dirty throttle...couple of years now and everything is perfect.....
04S60Jack
Year and Model: 2004 S60
Postby 04S60Jack » Tue Dec 22, 2015 5:27 pm
I started a day with my 2004 Volvo S60 starting right up just fine then shutting down within 30 seconds, This could be repeated up to 3 times then I was forced to wait 20 minutes before it would start up again. I went on line and found people changing their MAF , Cam Position and Crank Position sensors with mixed results. Then I ran into responses where people changed their Ignition Switch Antennae Rings or banged their keys into the ignition with a screwdriver handle to some success. I spoke with a parts dealer I know and he said it sounded like a security related immobilization of the engine. I thought it seemed like my car thought it was being stolen and the key wasnt being recognized. I hit the red alarm button on my key fob setting the alarm off then turned it off and low and behold i was able to start the car off and drive with no further problem. this is probably the beginning of an ignition switch or engine immobilizer problem down the road, but at least i'm on the road for free!
Year and Model: 1999 V70T5, 2005 V70
Flag: Trinidad & Tobago
Postby abscate » Wed Dec 23, 2015 2:57 pm
30 seconds running for an immobilizer problem is longer than I recall being reported before. It usually is reported as a 1-2 second interval.
I would guess an intermittent somewhere in the ignition switch or immobiliser rather than a code problem.
Interesting coding question though - is the immob active after starting or does it decide once it allows you to run the car, it stops looking for the chip and code? I would guess this, but don't know that for certain
"Its not your ECU, ECM, nor your computer"
1999 V70 T5 HPT 5speed
2003 Beetle Conv 5speed
2002 Eurovan
2005 V70 5speed
2006 BMW X3 E83
A houseful of young ladies seats 7
Shepard Husky, Lab
Grey, ginger,black cats
Lots of boats
jenkinskg
Year and Model: S60 2004
Postby jenkinskg » Tue Dec 29, 2015 2:35 pm
fuel pump controller on my 04 S60 died, if it is corroded a turn could cause cut out, bought one lifetime warranty $100 erie volvo used but tested parts
no issues since.
The controller get wet dirt etc in it, mine had florida beach sand in it and corrosion, was going to relocate like they did under warranty on S40
2004 c70 2.3HPT, S60 2.5T
Return to “Volvo V70 & XC-70 (2001-2007), S60 (2001-2009)”
Who is online
Users browsing this forum: Tonyx and 20 guests
