This Topic is in the Volvo Repair Database
2001 V70 2.4T Mass Air Flow (MAF) Sensor Cleaning...
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
E170_Driver
Year and Model: bye V70 2.4T, 2001
Postby E170_Driver » Thu Feb 04, 2010 4:35 am
To continue my endeavour of keeping my 2001 V70 2.4T running smoothly and learning more about this vehicle, I have decided to clean the MAF sensor which was next on my list of preventative maintenance. Tools required for this job was a straight edge screw driver, a T25 torx bit and a wrench. Costs involved were $6.99 for the MAF sensor cleaner and $24.99 for the air fliter (ouch, I will order from the internet next time).
The MAF is located right next to the air filter with an electrical connection attached to it.
From a side view one can see that there are two torx screws (sixe T25) which we will attend to later.
First one needs to disconnect the electrical wires to the unit; be very careful, the connector is very fragile. I used my straight edge screw driver to lift the plastic clip on the connector...
...and then pull the wires.
Next was opening the air filter housing (gotta pull a little to get it to free).
I loosened the clamp around the downflow part of the MAF housing. In order to remove the MAF unit (still attached to the top of the air filter housing) one needs to pull/wiggle a little to get them separated, just be patient and careful.
Here is a good view of the MAF sensor once removed. Notice the torx screws, yep they are next. There is a rubber seal located within this connection.
Once everything disassembled, here is what I got; in addition there is the rubber seal and air scoop (very easy to remove, just pull a little on both ends). Follow directions on the spray can for the cleaning process and then let the MAF sensor dry for 1-2 hours.
Back in the engine compartment I was left with the following; the lower part of the air filter housing, which was rather dirty indeed...
...so, I cleaned it and the air scoop (shown here after I installed it).
Before I went back to the car, I placed the rubber seal back into place at the opening of the air filter housing. After placing the new air filter onto the lower part of the housing, the challenge (on this model at least) is always installing the top part. It takes a little force to place the unit into its grooves and holes, once again a little patience and lining up the connections exactly goes a long way.
The back part of the housing...
...and the side part of the housing.
Once in place it ought to look something like this.
The label on the MAF unit makes installing it the right way rather easy (not that it would fit the other).
I first pushed the unit a little into place (u will get a little resistance from the rubber seal) until I can start inserting the Torx screws; then tighten the unit into place.
Then reinstall the aft end and tighten the clamp and there you go...
May I add, that by no means am I a listened/professional mechanic. I got tired of dealerships giving me the run around about what needs to be done with the car and with the help of lots of research (most of it from this website regarding my Volvo) have I started working on my own cars (the others being a VW and Jeep). My vehicle has now more than 138,000 miles and as mentioned before, I am just trying to do preventative and sometimes necessary maintenance in order to keep it running good. The cleaning of the MAF sensor is a rather easy thing to do, but I noticed that the car has some very rare subtle/slight hesitations while engaged to the cruise control (not trying to think about the ole ETM debacle on this model; I still have a white sticker with the updated download).
I would like to add one more observation. When I started the car for the first time after the MAF sensor cleaning, I noticed that the idle was fluctuating between 800 and 1200 rpm for about 10 seconds. I have read many accounts from Volvo owners having idling problems and would like to say that maybe a cleaning of the MAF sensor possibly solves some of these issues for certain folks. I meanwhile have driven the car and I blame the 10 seconds of erratic behavior on some liquid left behind on the sensor; no problems since then. We will see on Friday morning, going back up to Indianapolis (250 miles).
If there are any suggestions or corrections on what I should have done better, differently or not at all, please do; I will do this cleaning of the MAF sensor again.
Jan
Former 2001 V70 2.4T owner
seggs
Year and Model: '02 S60 2.4T FWD
Re: 2001 V70 2.4T Mass Air Flow (MAF) Sensor Cleaning...
Postby seggs » Thu Feb 04, 2010 2:46 pm
Where did you purchase the MAF cleaning spray?
confused_al
Year and Model: 1996 TLA wagon
Flag: United States of America
Postby confused_al » Thu Feb 04, 2010 3:27 pm
seggs wrote:Where did you purchase the MAF cleaning spray?
Any auto-parts store, pepboy, autozone even walmart.
As a lazy old fart, I clean my MAF from the other side (the screen side) without taking out the whole airbox. Just want make sure NOTHING touches the sensor.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
E170_Driver
Postby E170_Driver » Thu Feb 04, 2010 3:33 pm
AutoZone it was...
Jan
jblackburn
Year and Model: 1998 S70 T5
Postby jblackburn » Thu Feb 04, 2010 3:47 pm
Jan, this is an excellent step-by step write up with lots of good pictures :mrgreen:
I'm going to add this to the repair database, the pictures of the process will definitely help people (at least people like me who are better off seeing things) a lot.
Thanks again!
'98 S70 T5
2012 Chevy Cruze LT 6MT
E170_Driver
Postby E170_Driver » Thu Feb 04, 2010 3:52 pm
jablackburn wrote:Jan, this is an excellent step-by step write up with lots of good pictures :mrgreen:
Thanks again!
Morning JABLACKBURN,
that is exactly why I took all those images. For novice mechanics like myself, I need idiot proof explanations/pictures to guide me through the process; I realize that most of the steps are self explanatory/easy, but I mainly put this together for folks like myself.
Thanks
Jan
apollo5
Year and Model: S60, 2001
Postby apollo5 » Wed Feb 24, 2010 11:47 pm
I'm like you, can't stand getting taken to the cleaners. One dealer once sent out a "savings" where everything listed was only $189.99 even a full detail, $200 bucks to wash my car, $200 bucks to rotate my tires? I don't think so! Having small hands helps me get to tight areas also. Just replaced my front o2 sensor and if not for small hands to just reach the wiring harness which is a bear to release the locking connector.
Anyway, I'm going to clean my MAF. Your pics don't show on my computer but maybe they will when I get home and off my company's network.
Thanks
apollo5
Postby apollo5 » Fri Feb 26, 2010 3:00 am
What exactly gets sprayed on the MAF? What exactly is being cleaned off to make a difference? Can instructions don't help not a true mechanic, what are the "hot wires"?
crespo
Year and Model: S60 2001
Postby crespo » Fri Feb 26, 2010 8:43 pm
That's a great write up but you haven't actually shown how to clean the MAF.
For those that don't know the actual MAF is the bit that goes in to the round tubing held in with the two torx screws. You do not need to completely take apart the filter housing to get at it.
Simply unplug the wires connected to it, remove the 2 torx screws from it pull it out and spray it with carb or MAF cleaner. There are some thin wires inside the unit (these are the sensors), Spray these with the cleaner and allow to dry then re attach it. Job done. DO NOT USE A COTTON BUD OR ANYTHING TO TRY AND CLEAN THESE WIRES as you will kill the MAF, Just spray it.
The 2 torx screws are T25 security screws and have a little nipple in the middle so they cant be removed with a normal torx bit.
I use carb cleaner as it removes the built up dust etc on the wires without having to physically touch them with anything.
apollo5
Postby apollo5 » Sat Feb 27, 2010 12:54 am
Thanks Crespo!!!
Return to “Volvo V70 & XC-70 (2001-2007), S60 (2001-2009)”
Who is online
Users browsing this forum: velorider and 23 guests
