IPDVolvo PartsVolvo Salvage: Used Volvo Parts and Over 50 Years ExperienceSouthern Vo Vo sells genuine used Volvo parts
Volvo Parts
Buying gifts? Please use this Amazon link ... and help keep MVS on the Web. Thank you!Amazon.com
MVS Login
Register - it's Free!
Get Help
Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
Volvo Parts
Shopping Amazon.com? Help MVS by using this link!
Oil Cooler Hose Replacement
Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
Re: Oil Cooler Hose Replacement
Postby holler1 » 19 Oct 2011, 13:01
Crotext wrote:Were the O-rings you used Green like OEM or black furnished with the hoses?
Mine were green. I think they came with the hoses, but I also think I ordered some extra. As mentioned, I ruined at least one. I tried to install the hoses without removing the thermostat - Bad idea.
Thanks for the pic. I was lining the brackets up and it did appear that that is the way to
getting it right.
Thanks again.
Welcome, glad to help.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
holler1
Forum Member
Forum Member
Postby Crotext » 22 Nov 2011, 18:58
I am done with that job until I can check for leaks. I am starting another thread on a new issue.
I cut notches on the Thermostat side of the anchor brackets and inserted the screw in the block first,
then slipped the brackets on under a washer. Worked well. I also replaced the two screws on the thermostat
housing with #7 metric from ACE hardware. Using a a heavy flex shank screw driver, all three screws were
easily tightened down. Too bad I can't test for leaks yet.
Crotext
New Member
New Member
Model and Year: 850, 1997
Postby alschnertz » 27 Nov 2011, 02:29
Has anyone tried bypassing the cooler by cutting the lines and replacing with a piece of fuel line? It was mentioned above.
I would think it can be done, but access to cut the hard lines is tough.
I'd be concerned with metal shavings and dirt getting into the lines when cutting.
My car is hemorrhaging from the crimp area of the hoses. Got to get this fixed, the oil leaks are really making a mess of the driveway. The thermostat end is dry and doesn't appear to be leaking.
Trying to save some money by avoiding purchasing new lines.
'84 Prelude
'10 Mazda3, '06 MPV
alschnertz
Forum Member
Forum Member
Model and Year: 1995 854T
Postby MatDesign84 » 27 Feb 2012, 14:34
Anyone working on this problem and needing to save some money. This guy Orlando does great work at remanufacturing these lines. I purchased mine from him and they look very well put together and he didnt take any cheap short cuts. Plus he will even buy your old ones back from you that would otherwise go in the trash. auctions.volvospeed.com/DISCOUNT-9498-850VSC70-Turbo-Cooler-Lines--3-Money-Saving-Options,name,100046,item_id,0,ad_type,ad_details
Mat Design
Currently: 1997, 855 T5 | 1990 Volvo 240 DL
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
MatDesign84
Forum Member
Forum Member
Model and Year: 1997,855 T5
Postby aahmes57 » 28 Feb 2012, 18:01
SEARCH oil cooler line replacement
Feb 6, 2011 ... I have both oil cooler lines leaking at the metal fitting going into cooler. Has anyone found a kit available with all the O rings,
I THINK IT IS EASIEST TO CONNECT BOTH ENDS AND THEN PUT THE BOLT IN FOR THE BRACKETS
1991 740 (saved a life)
1998 S70 Turbo
1995 850
aahmes57
Forum Member
Forum Member
Model and Year: S70 Turbo 1998
Postby 1240 » 29 Feb 2012, 00:24
KLS wrote:Thanks for the info.
I think I'll consider using 1/2" I.D. hydraulic hose. I'll reuse the steel ends, strip off the crimp fittings, and put the new hose on with the usual screw clams...or have a local hydraulic hose shop crimp new fittings on. As long as the hose is suitable for oil at the pressure and temperature, it'll work find. Pressure isn't a problem. The temperature rating can be 250°F or 275° or something similar.
The oil filter can be removed without draining the oil. I may take it off if it gives more room.
This is an old thread, but I am new to this forum. I think a little precaution to prevent the assembly from coming apart would be a good idea. If the hose comes off the pipe you will lose oil quickly. Conceder putting a flair on the end of the steel line. The flair would prevent clamp and the hose from sliding off the end of the pipe.
1240
Postby MatDesign84 » 29 Feb 2012, 02:09
auctions.volvospeed.com/DISCOUNT-9498-850VSC70-Turbo-Cooler-Lines--3-Money-Saving-Options,name,100046,item_id,0,ad_type,ad_detailsOkay I just finished this job and have a tip that will save a lot of time and effort for everyone. I too was having a touch time getting the torx head bolt off at the thermostat and tried everything. I got to thinking of some old advice from dad for a similar situation and voila it worked. I managed to use a 4mm (may have been 6mm) allen wrench to get it off. I also used this method to get it back on again.
Mat Design
MatDesign84
Forum Member
Forum Member
Postby robocam » 04 May 2012, 06:09
I just tried to remove the two torx bolts through the wheel well, and I think I may have stripped the inside of the holes. Normally I would use a Dremel to cut slots into the bolt heads and use a standard screwdriver to remove them, but the area is too tight for that. I thought about using a drill bit to drill the heads off, but how do I remove the rest of the screw? I wonder if once the heads are off, if the studs would be easy to remove. Does anyone have any other ideas on how I might get those two bolts out? I hope I won't have trouble with the 4mm bolt holding the lines in. Thanks in advance.
robocam
Forum Member
Forum Member
Model and Year: 850, 1996
Postby holler1 » 05 May 2012, 02:03
Maybe a small Ez Out (screw extractor)? What size Torx did you try? I got mine out with a #30.
holler1
Forum Member
Forum Member
Postby xHeart » 22 Apr 2013, 17:33
robocam wrote:I just tried to remove the two torx bolts through the wheel well, and I think I may have stripped the inside of the holes. Normally I would use a Dremel to cut slots into the bolt heads and use a standard screwdriver to remove them, but the area is too tight for that. I thought about using a drill bit to drill the heads off, but how do I remove the rest of the screw? I wonder if once the heads are off, if the studs would be easy to remove. Does anyone have any other ideas on how I might get those two bolts out? I hope I won't have trouble with the 4mm bolt holding the lines in. Thanks in advance.
Oops...
I had struggled with the two torx screws on thermostat, first timer.
The design was such that the screw did not thread at the hosing cover, just passes through it. And then it would screw into the lower housing. Thanks to Ozark Lee for this info.
I was successful with the 1/4" left-handed-drill-bit, making counter-clockwise rotations to help it pull out at the same time, using oil to lubricate. Choose a bit size wider than the shank.
Golden Retriever
2001 - Volvo V70XC with +148kmi/ +238kkm
1997 - Volvo 850 NA (2.5L/5) Sedan with +133kmi/ +214kkm
Past:
German Shepherd
1989 - Volvo 740 GL
1979 - Volvo 240
xHeart
Senior Forum Member
Senior Forum Member
Model and Year: 850 NA Sedan, 1997
Postby jreed » 23 Apr 2013, 10:54
I guess I got lucky when I removed my oil thermostat a couple weeks ago. I used the tool set up shown below.
If it is of use, you can check out the DIY guide I wrote up here:
viewtopic.php?t=56014&p=282639
Please log in or register to see attachments.
jreed
Forum Member
Forum Member
Model and Year: '97 Volvo 855 GLT
Postby 98T5 » 23 Apr 2013, 14:08
HOw much oil and coolant is lost during this repair. I'm about to order my lines this week and get it done.
thanks.
98T5 Turbo - Fast
93' 940 - Slow
83' 242DL - Cool
98T5
Forum Member
Forum Member
Model and Year: V70T5,98' / 940,93'
Postby holler1 » 23 Apr 2013, 16:07
There should be no coolant loss, and only a little oil coming out, basically oil in the lines. I think most of the oil drains back into the engine when it isn't running.
holler1
Forum Member
Forum Member
Postby jreed » 23 Apr 2013, 22:44
+1 on that! I measured about 1/3 of a liter of engine oil coming out of the thermostat and lines, and there was more still in the lines and more that I wiped up on towels during the job. You won't need more than 1 liter of oil for topping up with at the end, assuming you don't remove the oil filter and drain out all the engine oil.
I would recommend removing the oil filter so you can lower the oil thermostat down and out more easily.
jreed
Forum Member
Forum Member
PreviousNext
Save thousands off MSRP on your new car.
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: Bing [Bot], Dirk1966, dosbricks, francisp, Google Feedfetcher, hausmeister, jblackburn, lewismug, loub, MSNbot Media, oldpnk3552, taxi, wega3k, wreid333 and 142 guests
