IPDVolvo PartsVolvo Salvage: Used Volvo Parts and Over 50 Years ExperienceSouthern Vo Vo sells genuine used Volvo parts
Volvo Parts
Buying gifts? Please use this Amazon link ... and help keep MVS on the Web. Thank you!Amazon.com
MVS Login
Register - it's Free!
Get Help
Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
Volvo Parts
Shopping Amazon.com? Help MVS by using this link!
Exciting Torque Steer!!
Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
Postby SimLyons » 01 Apr 2012, 19:37
Suspension and steering are probably the greatest weakness I have about my cars.
My 1997 850R Has new tires, relatively new Bilstein struts and upper bearings and runs true on the straight and level. Hitting the brakes beyond moderate causes a slight pull to the left.
But hard acceleration from a stop causes a wild ride! The torque steer runs it right nd left and right with constant quick corrections to keep me in my lane. In the meantime, my wife is all white knuckles with terror in her eyes. It's time to fix it!
I had it in to my local (excellent) tire shop for a full alignment. Then I asked then to check out the torque steer by driving it. The report was "it's all those grooves in the rods from the tractor-trailers and studs/chains". He also said there was no sign of looseness in the ball joints Well, my 2006R doesn't do it, no does my daughter's Prius. This is WAY beyond the norm.
I don't want to just replace everything willy-nilly. I would appreciate help! Thanks!
Sim
Sim
SimLyons
Forum Member
Forum Member
Model and Year: 1999 S80 T-6
Re: Exciting Torque Steer!!
Postby jblackburn » 01 Apr 2012, 20:45
I don't think a Prius can accelerate fast enough to pull in any direction besides straight. In the left lane of the highway. At 20 under the speed limit.
That feeling is usually is caused by bad ball joints or bushings on the control arms. If you have never replaced your control arms on this car, it's a pretty good bet. Jack the car up and check for any play at 12 and 6 o' clock shaking the front tires up and down (putting your hands on it and trying to push it back and forth towards the inside of the car). This will indicate that the ball joints are indeed bad
Do you see any uneven wear on the tires (usually on the inside edges)? This would point to bad tie rods, which can also cause pulling to one side under braking. These will show play shaking the tire side to side at 3 and 9 o clock.
'98 S70 T5 218K miles
2012 Chevy Cruze LT 6MT
jblackburn
Model and Year: 1998 S70 T5
Postby D_V_ENT850R » 01 Apr 2012, 20:48
Wow alot of $$ will be wasted. The car in question is an R and that means front wheel drive turbo. The S60R is (I believe all wheel drive!) The Prius just does not have the power to create alot of torque steer! If you replace all the suspension it's still not going to correct the issue. The issue is you have a powerful car that is front wheel drive. The traction control in the older models I believe only worked under 25mph. The newer S60R has a system that will start working over 5mph all through every speed. So the car and suspension is fine as the shop has informed you already. Keep your foot out of it and it won't do it. Or if you want to waste money give me that car and go buy another Prius.!!!! All front wheel drive cars have an amount of torque steer, the more power the more torque steer..
I'm on the 12 step plan..... 12 beers in a case...... Coincidence? I think not!!!
D_V_ENT850R
Forum Member
Forum Member
Model and Year: 850R 1996
Postby tjts1 » 01 Apr 2012, 20:49
With 295 lb/ft of torque starting at 0 rpm, you bet your sweet ass a prius can burn some low rolling resistance rubber. Problem is most prius driver's wouldn't know how to defeat the traction control.
Ambitious but rubbish
tjts1
Forum Member
Forum Member
Model and Year: 96 855 NA 5 speed
Postby JRL » 01 Apr 2012, 20:52
Brakes pulling should tell you something
2000 V70R Black, 121,000 miles (Wife's).
2006 XC70 White only 59,000 miles. New daily driver.
2000 V70R Silver, 36,200 miles!!! SOLD (I will regret this)!
Contact info for purchases: jrl1194 (at) aol (dot) com
JRL
Longtime Member
Longtime Member
Postby jblackburn » 01 Apr 2012, 20:52
Nope. A Camry hybrid could though.
jblackburn
Postby SimLyons » 01 Apr 2012, 21:48
Thanks guys! It's no coincidence that the torque is much worse this year than last, or 3 years ago, etc. I'd say it verges on dangerous.
I'll jack it up tomorrow and give it the checkover (wheel movement at 12-6 and 9-3 o-clock.) Won't hurt. And I checked those parts pricing at IPD. Not bad.
I suppose I am really comparing to all the past 850s I've had, mostly the T-5 and the 2006R. Of course, the grooves in the roads are all much worse and who the heck will fess up to having a budget to resurface them? It will only get worse.
Sim
Sim
SimLyons
Forum Member
Forum Member
Postby D_V_ENT850R » 01 Apr 2012, 23:15
But the R has more boost than T5! Therefore more torque steer! If everything is ok just drive it!
D_V_ENT850R
Forum Member
Forum Member
Postby jblackburn » 01 Apr 2012, 23:20
Not much. A s70 t5 has about the same power as an R. The only time I get torque steer is flat on the floor in first gear; it will not ever torque steer at highway speeds even flat out. Something's worn out.
jblackburn
Postby SimLyons » 01 Apr 2012, 23:55
First Gear getting lined up on the on-ramp..... I'm pretty gentle with it. When I'm certain I have the space I need to move out to traffic lanes I gun it (2nd gear) and away we go!! Hit those grooves in the pavement and it's wild west time! Mary is dead certain I'm on the way to the median strip, or in the next millisecond heading for the semi to my right!
I just want to tame it some, not kill it!
Sim
SimLyons
Forum Member
Forum Member
Postby BKM98 S70 T5 » 02 Apr 2012, 01:56
Are they Michelin, size and are they directional?
EDIT: Adding to a problem in the Suspension System per JRL - "Brakes pulling should tell you something"
BKM98 S70 T5
Senior Forum Member
Senior Forum Member
Model and Year: S70 T5 98
Postby matthew1 » 02 Apr 2012, 02:06
My gut says tie rods. I'm about to put new TRs in my 850 T after a. having similar behavior and b. replacing everything else.
Please buy from MVS sponsors. It keeps this site on the web.
Like this spam-free, organized forum? Thank a moderator.
Help keep MVS running: shop Amazon with this link.
Thanks for choosing MVS!
1997 850 T5
matthew1
Site Admin
Model and Year: 850 T5, 1997
Postby jimmy57 » 02 Apr 2012, 02:28
The toe should be set faintly toe out. On lots of FWD volvos over the years they reduced toe-in and then on some they changed specs to a very slight toe out. The lower control arm bushings being worn makes pull under brake and drive much worse as it lets settings change under stress.
jimmy57
Senior Forum Member
Senior Forum Member
Model and Year: 2004 V70R GT, et al
Postby SimLyons » 04 Apr 2012, 22:19
I just put the Michelins back on until the Snow flies again in late Fall. They are asymetrical 215/45R17 I think. My wife is using it today. The tires I used for Winter are studless Hankook Ice Bears and they behave exactly the same. So I can fairly well rule out tires. With the slight mods to the specs for alignment can anyone send me specs to give the tech when I have it done next? I'll replace a few other pieces first (see above).
Thznks for everything, guys!
Sim
SimLyons
Forum Member
Forum Member
Next
Save thousands off MSRP on your new car.
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: Bing [Bot], cbdbcbdb, chexny, chill75, FireFox31, Google Adsense [Bot], heisenbeis, Herb Goltz, jblackburn, macs70GLT, MattTheCat3, mynamemongo, olpossum, paredown, ryanmcgrim, sgroper46, shrtskts, SpeedyPete, steamnjn23, xHeart and 160 guests
