S80 Cornering Light Lens and/or Bulb Replacement 1999-2001
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
vegasjetskier
Year and Model: 2010 Toyota Prius
Postby vegasjetskier » Wed Dec 19, 2007 12:21 am
Broken Cornering Light lens? Bulb out? Here's how to fix it.
Pic of broken light:
Open the hood and locate the slot to insert the srewdriver to release the light.
The slot is in the center of this pic:
Insert the screwdriver in the slot and press down GENTLY on the plastic locking tab. If you press too hard, you will break the tab off (don't ask me how I know!), not an issue if you are replacing the light, but bad news if you're just replacing the bulb. Here's a pic with the screwdriver in the slot:
While holding the tab down with the screwdriver, gently wiggle and pull the light straight forward out of the opening in the car:
Here's the light removed from the opening:
The light socket is next to my thumb in this pic:
To remove it, grasp it firmly and turn it 1/8 turn counterclockwise:
Then pull it straight back out of the opening:
Here's the opening in the car with the light removed:
Here's the light removed from the car:
To remove the bulb from the socket, gently push in on the bulb and turn it 1/8 turn counterclockwise, then pull it straight out:
Reverse the above procedure to put it all back together.
I got my new light online for about $57. God only knows how much the dealer would have charged me to fix this.
Thanks for looking and Good luck!
Hey MIJ, feel free to add this the repair procedure list.
Help this site: Amazon.com link, Tirerack.com link, Donate
Flag: United States of America
Postby MadeInJapan » Wed Dec 19, 2007 12:55 am
Done! Now in the repair database for S80's!
trekking
Postby trekking » Wed Dec 19, 2007 10:50 pm
The plastic locking tab tends to break, even without being touched. The effect is an S80 with one (or two) cornering light hanging out of the body on about 20 cm of wires. The wires are indeed strong, you don't loose the lights even at highway speeds.
It could look really funny for the others, you notice it from the sould of their horns :wink: , but it is quite scary when you notice it on your own car :(
Fixes are to replace it; to glue it in somehow; or to drill a vertical whole near the broken tab and fix it in position with some small rod.
TimsVR6
Bulb Size
Postby TimsVR6 » Fri Feb 08, 2008 6:14 pm
I am new to the Volvo world. But I have a 2001 S80 and I wanted to change the front turn bulbs to Chrome ones. First off as in other messages, you might want to buy new corner lenses cause the tabs do break with no effort. Second online and in books they say the bulb is a 1157 and that is not right in my case. I found out the bulb is a 7507-A.
Tim
akuleana
Postby akuleana » Sun Oct 05, 2008 4:26 am
Does this work for 2002 S80 too? Thanks
billofdurham
Year and Model: 855, 1995
Postby billofdurham » Sun Oct 05, 2008 5:30 pm
It is the same procedure.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
akuleana
Postby akuleana » Sun Oct 05, 2008 7:28 pm
It worked Bill, thanks a bunch.
billofdurham
Postby billofdurham » Sun Oct 05, 2008 9:47 pm
You are welcome. Thank you for the update.
Bill.
Previously:
DanV
Year and Model: S80 2005
Re: S80 Cornering Light Lens and/or Bulb Replacement 1999-2001
Postby DanV » Thu Oct 08, 2009 1:31 am
This worked for my 2005 S80 also, same procedure, but I am having a problem getting the new replacement lens to lock in place (I am replacing a broken lens, complete with new bulb). The old lens came out easily, but despite my best attempts the new lens refuses to click in, although it stays in place by simple friction. The tabs on both the old and new lenses appear identical, so maybe I just need to push harder? I have given it a strong shove with the palm of my hand, but it just pops back out maybe 1/4" beyond the neighboring headlight. Any ideas?
Familytruckster
Year and Model: S80, 2000
Postby Familytruckster » Fri Apr 09, 2010 3:33 am
I'm trying to complete this repair and have hit a bump. I lost the entire driver side turn signal lens, bulb socket and electrical wiring connectors (just 3 bare wires hanging). I have the light lens and bulb/socket replacement parts but have been unable to find the 3 wire female pigtail or connector that attaches to 3 prong male bulb socket. How do I complete this repair? What parts do I need (local volvo parts dealers say the part is not available)? If I need to splice the wires what are my options?
Return to “Volvo S80 Forum”
Who is online
Users browsing this forum: Bing [Bot], jpkuntz and 17 guests
