2000 S80 T6 DCTS codes, special question "shift solenoi
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
daveloeffler
Postby daveloeffler » Mon Jan 14, 2008 9:49 pm
Hi all,
Previously I asked about the transmission. I got a reply to change out my fluid for synthetic. I am going to do that, just waiting on new filter. Here is another question, I purchased an OBD II reader and pulled these codes out.
P0237-Turbo boost sensor A circuit low
P0236- Turbo sensor A circuit range/performance
These were the first two to show up.
After letting the car warm up, as it tends to shift better when so. I took it out for a test drive.
Just as I was finishing the drive I was going up a slight incline at about 27 mph. The tranny jerked and two new codes also came up.
P1618-Fault in lead between AW50-52 and Mototronic 4.3 (MIL requested)
This one I think is the computer saying turn on the ! light.
Here is the real cause of the previous code and this is where my question get a bit more specfic, as if it is not already....
The code came in this
P0756- Shift solenoid B performance or stuck off.
Does anyone know if this solenoid is and internal part of the transmission? If it is where may I find documentation proving this? I currently have a third party warranty company and their claim is that it is not covered. I still plan on doing the flush with synthetic as I have already purchased the fluid and filter. What should I do about the solenoid.
I know this is a very confusing issue, can anyone give me some guidence. Thanks so much.
Dave
billofdurham
Year and Model: 855, 1995
Postby billofdurham » Mon Jan 14, 2008 10:54 pm
Dave,
After much shuffling to and fro through VADIS working out which gearbox may be fitted to your car I have found that code P0756 relates to Volvo code TCM-000C which is solenoid 2 hydraulic fault.
However, no matter which gearbox I have looked at it would appear that all the solenoids are in a control system box which is bolted to the outside of the gearbox.
This is probably what you did not wish to learn but if you can confirm the type of engine and gearbox I shall look further.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
vegasjetskier
Year and Model: 2010 Toyota Prius
Postby vegasjetskier » Tue Jan 15, 2008 1:08 am
I could be wrong, but I'm pretty sure you have a GM 4T65EV-GT transmission.
Help this site: Amazon.com link, Tirerack.com link, Donate
billofdurham
Postby billofdurham » Tue Jan 15, 2008 7:13 pm
That's what I worked it out to be. What threw me was the mention of the AW50-52 until I realised it was only the TCM asking for the MIL to be turned on.
Bill.
Previously:
les & reilly
1999 S80 t6 se auto transmission problems help please
Postby les & reilly » Wed Jul 02, 2008 2:05 am
hello,
i have just aquired a t6 and my auto xray is indicating exactly the same transmission faults. i rang the dealer and he said my car doesnt have the gm4t65eg box in it, it has another type. he said the sensors etc are in a housing built in and the complete housing is needed. at a cost of approx
les & reilly
problem solved
Postby les & reilly » Thu Jul 03, 2008 10:10 pm
hiya,
i have had exactly the same codes from my auto x ray reader.
i eventually found it a very simple, 20 minute 50p repair.
if you are still having the same problem, get back to me and i will tell you what it is most likely to be.
regards,
les
les & reilly
back to the drawing board
Postby les & reilly » Sat Jul 05, 2008 1:56 am
well, well, well. would you believe this.
found an open circuit (bad earth wires connecting together) behind the washer bottle and ecu box to plug at gearbox end (letter k) black wire.
fixed it and yes...i dont believe it !! still wont shift out of 3rd gear and goes into limp home mode.
so back to the drawing board for me...
will get around to changing the box oil, but uncertain if the oil ive bought dextron 3 is the correct fluid?
anyone tell me?
it says in my new handbook not to use anything other than volvo fluid, but do they just say this to get even more coin from our pockets?
my gearbox is an geartronic gt. in my 1999 S80 t6
Return to “Volvo S80 Forum”
Who is online
Users browsing this forum: No registered users and 9 guests
