IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    PCV Oil Separator wrongly routed IMPORTANT, EVERYONE READ!
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby MadeInJapan » 09 Feb 2008, 17:00
    Although not from our site here I thought this was really excellent and have added it to the repair database.
    http://lakesidedp.com/uploadpics/pcv/
    If you're having trouble even after your PCV replacement, check your PTC nipple as it probably is clogged. The write-up includes this. This is the first time I've seen it mentioned on a PCV how-to!
    Regards,
    MIJ
    JUST EDITED:
    IT IS IMPERATIVE THAT YOU SCROLL DOWN AND READ MY 17, 2008 9:58 PM POST
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby lewismug » 09 Feb 2008, 17:24
    That write-up would have been really, really nice to have as a reference last year when I tackled the PCV job on my S70! Thanks for the link MIJ. I'm sure that will help plenty of folks!
    lewismug
    Forum Member
    Forum Member
    Model, Year: 1999 S70
    Postby MadeInJapan » 09 Feb 2008, 18:19
    Always glad to help. Yes, it would have helped me a couple of years ago when I did mine too.
    In the meantime, it appears that if anyone is having PCV trouble, CHECK YOUR PTC NIPPLE FIRST
    Very helpful post
    Postby redbrick » 09 Feb 2008, 19:43
    That is a very nice writeup. Thanks.
    94 - 940
    97 - 850 T5
    99 - V70 GLT
    05 - V50 AWD T5
    redbrick
    Forum Member
    Forum Member
    Postby tailor » 09 Feb 2008, 21:15
    Fantastic write- up could have used that a few months ago. :(
    An extra check, make sure the rubber on the bayonett connector is not saturated with oil and has lost it's hold on the turbo hose, thereby letting un-metered air in.
    1994 850 Auto Turbo wagon 306000km (Sold)
    2004 XC90 AWD 188000km
    "Life is like a reel to reel tape recorder,
    the closer you get to the end,
    the faster it spins."
    Abe Gottschalk
    tailor
    Forum Member
    Forum Member
    Model, Year: 1994 850 Turbo Wagon
    Postby MadeInJapan » 09 Feb 2008, 22:31
    Right...when that happens there really is no good corrective measure and your only remedy is to replace the entire accordion hose (it comes with the PTC Nipple). The good news is that fcpgroton (and I believe eeuroparts.com) sells these and they aren't really that bad of an expense. So, to recap:
    1. Check the PTC Nipple which is on the bayonet connector at the bottom of the accordion hose from the air filter housing to the turbo. If it's clogged, unclog it (drill bit if it's solid, pipe cleaners with brake fluid, alcohol or whatever works) and if the bayonet connector is bad, go ahead and order the accordion hose.
    2. See if after #1 is done your PCV system is breathing correctly (no smoke from the oil dipstick tube when idling a warm engine, and no positive pressure when you hold your hand over the oil cap filler neck).
    3. Go ahead with the PCV replacement if #2 is still a problem.
    THIS IS IMPORTANT- EVERYONE READ THIS!
    Postby MadeInJapan » 18 Feb 2008, 03:58
    Something else I just found over on V.S. that I think everyone should be aware of. Both the diagrams over at FCP and those in VADIS show a confusing routing for the hose from the air intake and the one that goes up to the top of the engine from the oil separator (They are wrong for pre '99's).
    Please make sure you get it right. It will make a difference. This is the correct routing:
    If routed wrong, it will send oil into your turbo and thus into your intercooler pipes. Here is why:
    The condensation rolls down the side of the walls of the oil separator and back into the engine. There's a baffle in the center of the plastic box that allows exhaust back into the air intake without the oil. If the hoses are reversed then the oil trap would become saturated without a way to re-route just the exhaust. Instead, oil would be routed (also it will clog faster). This might be why some complain of more oil in their turbo hoses after the PCV replacement and then wonder if their turbo is going out.
    When I read the above, I had to go check my routing. It is hard to tell once the intake is back on but with a strong flash light you can peer down from between the fuel rail and the engine and tell that the hose routed to the top of the engine is a shiny black one whereas the the one routed to the the air intake (accordion) hose is more matt black. Just to make sure I found a coat hanger and jiggled the shiny black hose and it moved the hose all the way up to the top one at the engine so I was relieved.
    Postby chuckcintron » 18 Feb 2008, 15:49
    Whoa! This is pretty interesting. I did this PCV job about 7 months ago, and have since developed an oil leak around the turbo. I figured something was up with the send/return lines at the turbo, and I would just address it in the spring, when the weather gets warm enough to work out in the garage again.
    So, for my 1997 GLT you are saying that the topside routing of the box is essentially backward, in the FCP/VADIS diagram, right?
    I'm going to have to check this tonight when I get home. Since I usually print those diagrams off and follow them when I'm working on the car, there's a pretty good chance it was done wrong.
    If it's been installed backward all this time do you think the breather box is saturated and now needs to be replaced? The thought of doing this job again is not a very happy thought, right now... :cry:
    -Chuck
    chuckcintron
    Forum Member
    Forum Member
    Postby MadeInJapan » 19 Feb 2008, 01:55
    chuckcintron wrote:So, for my 1997 GLT you are saying that the topside routing of the box is essentially backward, in the FCP/VADIS diagram, right?
    -Chuck
    Yes, there is a possibility that you installed it backwards. I believe someone over on V.S. has been in contact with FCP so hopefully they'll change their diagram....and VADIS seems wrong as well...at least from the actual construction of the oil separator. I'm trying to thing what would happen if you didn't change out the separator. Maybe, taking it loose and dumping the oil out the top would be enough to restore things...but if you do that far, why not just replace it? I think the other hoses would be ok and would clear on their own after a few hundred miles. Yes, it is a :cry:
    Just check with a strong flash light when you get a chance...it is a tight view but you should be able to tell without taking the manifold loose.
    Sorry for this bad new (but hopefully you're ok).
    Postby chuckcintron » 19 Feb 2008, 03:10
    Well, good news...with my billion candlepower light (well...not quite...) I was able to see the routing, and for some strange reason I had it correct.
    Oil leak must be something else around the turbo...I may have to check that intake PTC area again.
    Whew. :shock:
    Thanks,
    Chuck
    chuckcintron
    Forum Member
    Forum Member
    Colour pic of oil seperator
    Postby tailor » 21 Feb 2008, 01:45
    Here is a nice colour picture of the fitting.
    Double click the pic to read script boxes.
    I hope this is clearer.
    Abe Gottschalk
    tailor
    Forum Member
    Forum Member
    Postby MadeInJapan » 21 Feb 2008, 04:24
    Thanks for the great picture!
    I'm making this thread a sticky.
    Postby luketrash » 13 Mar 2008, 21:24
    Before I dismantle my car, do the N/A cars have the PTC nipple?
    I have smoke blowing out the dipstick hole and have had for the entire time I've owned the car, including my PCV system complete replacement, including pipes/hoses. My 1994 model is a bit different than pictured above.
    '94 Gunmetal Gray 855 2.4L 100% stock. This is Volvo #7.
    luketrash
    Forum Member
    Forum Member
    Postby Ozark Lee » 13 Mar 2008, 21:51
    Neither of mine do. One is a '94 and the other is a '96 but I found out yesterday that the motor in the '96 is actually out of a '94 or '95.
    '94 850 N/A
    '96 850 N/A
    '98 S70 T5
    '99 V70XC
    Previous: 1989 740 GLT
    Next
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: Ben850, bgfl2020, ChillyOne, xHeart and 80 guests
