IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    Check Engine Light on 97 Volvo 850
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby chn718 » 12 Apr 2008, 05:49
    Hi all, I recently bought a 97 Volvo 850 wagon with 150,000 miles on it, recently it has been having problems starting, I would need to turn the key once and the engine would crank, but it would not start, if I let it go and then crank it again it would start. I took it to my mechanic and he said the spark plug wire was shot/burnt and so he replaced all the spark plugs and the spark plug wire, and distributor cap I believe, or whatever else is related to the spark plugs. It started ok maybe the first 2 times but now 5 days later, it's still having the same problems and recently the check engine light just came on while I was driving it, I took it to autozone and the guy said it says that the car is running with too rich. Has anyone else experienced this problem? Does anyone know what the source of the problem might be? How many more miles might I get out of this car? Thanks !
    chn718
    New Member
    New Member
    Postby MadeInJapan » 12 Apr 2008, 12:53
    Knowing the exact code would help but "too rich" a condition can be from numerous sources. I would check all of my little hoses to make sure there are no breaks in them. Some small breaks are hard to spot. Spray some carb cleaner around the hoses with the car idling and you'll know where the holes are when the car surges. Usual culprits are the hose elbows closest to the engine. Another thought is, what did your mechanic use for replacement parts? Plugs and wires especially are things these cars are picky about. They don't like Bosch Platinum plugs (stick with Bosch copper or Volvo plugs) or Bosch wires...Stick with Bougicord wires (OEM). Let us know what you find. That said, a "rich" condition can also be the result of a bad oxygen sensor. At 150K miles, if the front one hasn't been replaced, it's time. So to summarize, do the cheap stuff first and if that doesn't get it, then the 02 sensor. Once again, knowing the specific code would certainly help.
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby pgd94850 » 12 Apr 2008, 14:14
    I bought my 94 850 with about 150,000 almost 2 years ago and its about to turn over 200,000. I have had 2 issues with a crank no start senario. Can be very frustrating. People prob could give you 30 things to check but might not be related to your trouble.
    I agree with MadeInJapan, Best to get the exact code. I would check this first before replacing a lot of parts. Mine does not have an odb2 diag it has an onboard diagnostic unit. Once the codes are read clear and see if any trouble codes appear.
    pgd94850
    New Member
    New Member
    Postby Sperry » 13 Apr 2008, 02:02
    What's the connector beneath the coin dish?
    1994 850 Turbo Sedan. 202,000, and getting more experienced, not older. - sold
    Sperry
    Forum Member
    Forum Member
    Model, Year: 850 Turbo 1994
    Postby MadeInJapan » 13 Apr 2008, 02:07
    That's an OBD connector. Some people who have 850's as early as '94 had both this connector and the diagnostic boxes under the hood. The diagnostic boxes will read ALL of the specific Volvo codes while from the OBD you can only read generic codes unless you have the mega expensive Volvo Scan Tool (VST), so if you want just a quick code reading and don't mind the generics, you can use the connector under the coin holder.
    Postby Sperry » 13 Apr 2008, 02:11
    I've checked A-7 codes, but should one routinely check the other spots, even if there is no check light? Like A2, etc?
    Does one always start off with a single push of the DTC button?
    Sperry
    Forum Member
    Forum Member
    Postby MadeInJapan » 13 Apr 2008, 04:56
    A-7 is only the instrument cluster (and to reset your service light). A-2 is the Fuel system. There is a list of pertinent sockets for the codes here: http://www.matthewsvolvosite.com/chat/p ... hp?t=10758
    You start off by pushing the button for one full second to retrieve the codes no matter which socket you're using.
    Hope this helps.
    MIJ
    Service Light 93 GLT 178,000 mi.
    Postby Hot Pepper Thai » 07 May 2008, 05:18
    To all the 93 GLT's Lovers. I have tried to reset the service light. I've tried the 1-5-1 that was in the blog and notta. If anyone and this is the OBD-1 people can let me know how does one remove the service light. I read about remove the bulb, but that's not what I really want to do. All suggestions are welcome! HPT. THANKS (93 GLT)
    98 S70 T5 black and gray, K&N, Lucas, Pennzoil SYN.
    93 850 GLT white
    Hot Pepper Thai
    New Member
    New Member
    Re:
    Postby milesursogood » 04 Oct 2009, 05:24
    sperry, so if you have the OBD connector only, what type of scanner did you use? and where did you purchase it? thanks.
    Sperry wrote:I've checked A-7 codes, but should one routinely check the other spots, even if there is no check light? Like A2, etc?
    milesursogood
    Forum Member
    Forum Member
    Model, Year: 850 T-5, 1997
    diagnostic socket
    Postby milesursogood » 04 Oct 2009, 21:27
    where exactly is the diagnostic boxes under the hood of a '97 850 T5 wagon?
    MadeInJapan wrote:That's an OBD connector. Some people who have 850's as early as '94 had both this connector and the diagnostic boxes under the hood. The diagnostic boxes will read ALL of the specific Volvo codes while from the OBD you can only read generic codes unless you have the mega expensive Volvo Scan Tool (VST), so if you want just a quick code reading and don't mind the generics, you can use the connector under the coin holder.
    milesursogood
    Forum Member
    Forum Member
    Re: Check Engine Light on 97 Volvo 850
    Postby MadeInJapan » 04 Oct 2009, 21:46
    There shouldn't be any diagnostic boxes under the hood on a '97. Only the OBD-II connector under the coin holder.
    Postby Sperry » 05 Oct 2009, 02:26
    There is a little user-accessible box under the hood, with a lead wire and different sockets in which to plug the lead. A button and flashing light are the only other interface.
    Under the coin tray is a reader socket, but I have not yet borrowed a reader to see how it works.
    milesursogood sperry, so if you have the OBD connector only, what type of scanner did you use? and where did you purchase it? thanks.
    Sperry
    Forum Member
    Forum Member
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: 98volvotank, bojified, bskeels, erikv11, Google Adsense [Bot], j-dawg, kahl, Kuhnman, kumagan, mikilla, neworleans, paredown, rumedina and 103 guests
