List of faults:
1) swishing water sound when the fan is on high
2)water coming into the passenger side when turning left
3)fan bearing starting to groan when turning left
4)sucked out about 2 litres of water from the fan housing, see 3rd pic.
Now other than these problems..... the A/c works and keeps us cool.
No fault codes either!
What do you learned folks think?
In spite of my cabin air filter you can see junk at the bottom of the fins .
The above pictures are taken through the blower motor housing. The orientation is correct.
Just very damp inside, all the water had been removed with vacuum pump, see below.
We have had an extraordinary amount of wet weather here in Toronto, I had put it down to a leak through the windshield
and the fact that I park on an incline.
Vacuum pump/brake bleeder
Any idea if I can drive around with the blower motor out and should the A/C cycle? It will be Monday before I can get my hands on some parts.
1994 850 Auto Turbo wagon 262000km on fixed clock and climbing.
Mobil 1.Silicone intercooler hoses and vacuum pipes.
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
