volvos expensive to work on??
Gidish
Postby Gidish » Sat Jul 31, 2004 12:21 am
I'm looking to purchase a volvo c70 '98 and have heard rumors about maintenance. Are they reliable? What is the avg lifespan of the car before it becomes a lemon? And of course, how pricey are parts? Any info regarding volvo is appreciated and will aid in my decision to go with volvo or another company. Thanks in advance.
csbrianp
Postby csbrianp » Thu Aug 12, 2004 12:00 am
I have a 98 Volvo S90. I bought it used a couple of years ago for my wife, and worried about the same thing at that time. Now two years later, I have replaced a serpentine belt, a seat heater switch and a couple of the instrument lights that were burned out. I find doing the little things like that easier than on the Honda I had before. We drive this car to and from California on once a month, and have had no problems. It's been so dependable I bought a 94 850 turbo last year, and have experienced the same reliability.
Also, taking any car to a dealer can be a costly decision, so I would suggest finding a local mechanic that you trust to do your work.
Brian
Stormin Norman
Postby Stormin Norman » Thu Aug 12, 2004 8:06 pm
With the exception of dog cars like a 99 S80, which was bad from the git go, well maintained Volvos don't ever become lemons. Instead they last for a real long time. Pro-active maintenance, preferably with a Volvo experienced IM, is essential to keep these cars running for a long time.
Exspensive? A Volvo water pump (as an example) costs twice what a Ford or Chevy does. It also lasts 3 to 5 times as long! Seems like the Volvo is cheaper to me in the long run. Volvo parts are usually far cheaper than BMW or Mercedes parts. A Volvo has a lot more in common with a Benz than a Dodge.
Buying parts at the dealer is usually a big rip. Local dealer wanted 62.00 for a radio power antenna mast (minus my 10% club discount) IPD charged 22.00 for the same part.
I think these cars are very good for the money. But I also believe that
"Quality is the only bargain". (Benjamin Frankin).
potroast
Postby potroast » Thu Aug 12, 2004 8:38 pm
buy your parts online.
do the work yourself.
If you do that, you'll have a fine time. If you take it to a shop, I hope you're rich.
I'm at 164k miles, and I'd be VERY disappointed if I got any less than 250 out of it!
Tsquared
Year and Model: 11 C30
Postby Tsquared » Thu Aug 12, 2004 9:58 pm
potroast wrote:buy your parts online.
What he said...
Good Advice. I would also recomed getting a Hanes Manual. Also change your trans fluid every 30 K miles.
Good Luck,
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
TAFinley
Postby TAFinley » Tue Aug 17, 2004 5:39 am
I agree with potroast. Buy your parts online and do the work yourself.
My 1985 245GL has 162K (US miles) with the original engine, starter, alternator, fuel pumps, power steering pump, and air conditioning components. It consumes about a quart of oil every 3K and doesn't leak at all (no drips on the garage floor).
Automatic transmission was rebuilt at 127K. New, "late-model", engine wiring harness (1/2 paid for by Volvo!) installed at 116K. Steering rack (ZF) was replaced at 95K.
So, what hasn't been so good? It needs a water pump every 40K or so and it seems to burn up the overdrive relay about every 4 years. Also, the wiring going through the tailgate (station wagon) has always been a pain. The body has had some issues with rust (but I live in the Northeast US where they spray salt solution everywhere if the weather people even hint that there might be snow).
But... It's been 100% reliable (has never broken down in 19 years) and I routinely drive it on long trips (>300 miles) without fear of breaking down.
Tom Finley
'97 854 T-5
'85 245 GL
Guest
Postby Guest » Tue Aug 17, 2004 3:03 pm
I also have a '7 854 T-5.
It has 52K miles and the only unexpected repair has been a new alternator (covered under warranty) at 1200 miles. The car has never broken down.
Now that it's seven years old, I'm doing a good bit of maintenance on it to get me through the next seven or so years. This summer, I've recharged the air conditioner, replaced the front rotors, brake pads all around, serpentine belt, and timing belt. Within the next week or so, I'll be replacing the upper engine mount bushing (it cracked). It's now on its second battery and second set of tires. I've not had to do any exhaust work yet.
The maintenance I've performed was recommended by the Volvo dealer at a cost of about $1500. For about $300 in parts and some of my time, I've taken care of all this maintenance myself.
dan_burdock
Re: volvos expensive to work on??
Postby dan_burdock » Thu Aug 19, 2004 1:53 pm
I'd look else where my 850t5r has been the most unreliable car I have ever owned. Bought with 50 thousand on clock from reputable main dealer. 1 owner from new, full volvo service history. Had it for one year. New ABS tracs pump + ecu over a grand, air con faults totaling 500 gbp, scuffed tyres 2 sets after 10,000. 2 wheel bearngs, famous PNP switch, new lamda, failed CAT and now after 1 year I am sick of it, it has never been right since first purchase, I have had loads of time off work. I have owned 2 alfas which I thrashed the hell out of, tyres were the only real cost,
I have never thrashed the volvo, I can't for fear of some costly bill, When they say Volvo for life, they mean once you have bought it you can't get rid of it.
Dan
Guest
Postby Guest » Thu Sep 16, 2004 9:44 pm
I have an 850Turbo, '95. Bought with 112k miles. Now it has about 150k. I've abused it quite a bit - almost 40k in 2 years. Few problems, other than PNP and now the evaporator is leaking. Everything else is regular maintenace/consumables. I have a mechanic (non dealer) do all of the work - 1/2 price vs. the dealer.
I did have the coolant hose attached to the turbo break a year ago. I think that the quick-oil-change people broke it.
Expensive? More than my Chevy, but the parts last longer. I like the Chevy and the Volvo, both are good. I've never had to do an alignment on the volvo. Chevy needs it annually. ]
dan_burdock wrote:sts less to fix each time. Volvo doesn't break much but costs more to fix each time. My time is valuable, so the Volvo is better value. And, it is damn fast too.
You got a dud here. Sorry for the luck.
dan_burdock wrote:I'd look else where my 850t5r has been the most unreliable car I have ever owned. Bought with 50 thousand on clock from reputable main dealer. 1 owner from new, full volvo service history. Had it for one year. New ABS tracs pump + ecu over a grand, air con faults totaling 500 gbp, scuffed tyres 2 sets after 10,000. 2 wheel bearngs, famous PNP switch, new lamda, failed CAT and now after 1 year I am sick of it, it has never been right since first purchase, I have had loads of time off work. I have owned 2 alfas which I thrashed the hell out of, tyres were the only real cost,
Dan
bigc
Volvo 96 850R
Postby bigc » Thu Apr 21, 2005 10:25 pm
:cry: Avoid the Swedish (Now Ford) Monster. I have a '96 R wagon and the car has a very bad electrical system. It has been through two traction control computers ($400 each) and the ignition has had to be replaced. These electric problems are well documented in various forums. Don't be fooled - these are expensive cars that have lots of expensive problems. If you aren't mechanically inclined and don't have access to recyled parts (a yard specializing in Volvo's)stay away from these cars ...
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: abscate, Bing [Bot], erikv11, kevinwalter and 40 guests
