IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    Glovebox wont open, Broken Latch >>Fix<<
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby Mister-93 » 02 Feb 2005, 23:52
    I found awesome great advice on this site. I have one hope it helps someone, let me know.
    My glovebox latch broke on my 93 850GLT. The door handle would not unlock the box. I did the hacksaw trick. I used two large thin metal putty knives on either side of the hacksaw to protect the vinyl. Put the saw blade between them and cut thru both sides of the U shaped latch. After cutting thru both sides of the U shaped lock the door was open! The dealer in Ohio wanted to sell me a complete glovebox door, (over 100 bucks)! I had the parts guy pull up the schematics to see how to install it. I noticed the locking mechanism had its own part number. So i purchased a lock/latch mechanism kit and it had the U shaped bar in it that I had to cut in two to get in the box. Cost me about 17 bucks. Take the door off of the dash. Remove the door liner screws and door liner to expose then locking mechanism. >> Pay close attention to how all the gears and levers come out<<<
    Reverse install the new hardware. Reinstall the door to the dash.
    Mister-93
    this makes it even easier
    Postby dugitman » 03 Feb 2005, 02:57
    I got in and then just used velcro to hold it shut. I didnt care about locking so much. If u use velcro method, scrape felt down to plastic with a razor blade. Velcro seems to hold tighter than the Volvo mechanism and i hate goofing around with itty bitty parts. Getting one of these ($5.00 made by stanley) speeds things up.
    Image[/img]
    The sprinklers that come on at 3am sound like crowds of people asking-- "Whatcha doin to that 850?"
    dugitman
    Forum Member
    Forum Member
    Postby lightangel » 19 Feb 2005, 06:24
    I did the same thing to my glove box.
    the latch is broken at the position where the shear stress is very heavy.
    Unfortunately, I can see a pore there, which is a casting defect.
    the latch itself is around 40 dollars, so I just bought a used glovebox from Ebay, where I got everything including the pocket.....
    lightangel
    Postby robert213 » 04 Dec 2005, 19:27
    I finished a couple of small projects in a weekend in September. I was hoping to show pics of work-in-progress, but I used up my allocation of space on my ISP's server.
    Project #1 -- Adding a thin wire to glove box latch
    I couldn't find a thin wire, so I used a twisty-tie wire from my box of garbage bags. Like threading a needle while sewing, I ran the twisty-tie wire thru the loop behind the latch pin. I tied each end of the twisty-tie wire in a square knot -- making a small loop. I placed black electrical tape over the small loop keeping it flush with the top of glove box door.
    By adding a thin wire (preferably fishing line), a person has an alternate means of releasing the door latch -- a back-up plan, to anticipate that the normal handle will break off at some point in the future.
    Project #2 -- Installing deer whistles behind black inserts in front air dam
    I bought a nice set of deer warning whistles at Wal-Mart. They are made by Bell Automotive. They are two-piece such that the whistle can be removed and re-attached to its base.
    http://www.bellautomotive.com/asp/product_details.asp
    I made note of the torx screws fastening the front air dam to the bumper. I drilled out the rear hole of each of deer whistle mounting base to allow for the diameter of torx screw.
    I removed and used torx screws to fasten deer whistle mounting bases behind black inserts in front air dam. I removed double-side tape and added a dab of Permatex Black RTV to each mounting base.
    I regret that I am not able to provide pics.
    robert213
    Forum Member
    Forum Member
    Postby MadeInJapan » 04 Dec 2005, 21:47
    I couldn't view your pictures. I too would like to do this. With winter here, I'm often driving in the dark on the interstate and often see deer along the side of the road...some are living, but some, unfortunately have been hit. I don't want my Volvo to have the same fate.
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby matthew1 » 05 Dec 2005, 02:18
    Robert, send me pics mattATmatthewsvolvositeDOTcom and I'll host them. Any text you care to also.
    Please buy from MVS sponsors. It keeps this site on the web.
    Thanks for choosing this Volvo Forum to get your Volvo info.
    Like this spam-free, organized forum? Thank a moderator.
    1997 850 T5
    matthew1
    Site Admin
    Model, Year: 850 T5, 1997
    Postby matthew1 » 05 Dec 2005, 06:03
    Thanks!
    Project #1 -- Making an alternate means to open glove box.
    I couldn't find a thin wire (e.g. fishing line), so I used a twisty-tie wire
    inserted the twisty-tie wire thru a hole in the latch pin mechanism. I tied
    covered the loop wire with black electrical tape, keeping it flush with the
    By pulling on wire loop, a person has an alternate means of releasing the
    Project #2 -- Hiding deer whistles behind vents in air dam.
    I bought a nice set of deer warning whistles made by Bell Automotive. I
    found mine at Wal-Mart. They are two-piece such that the whistle can be
    I observed the location of torx screws fastening the front air dam to the
    1997 850 T5
    matthew1
    Site Admin
    Postby Jake of Sigourney » 09 Apr 2006, 07:22
    1994 850 wagon glove box catch broke, and fixed it in about 2 hours, better than new. Pried door open just enough to slide fine toothed hack saw blade in and cut both sides of wire loop that fits into door latch. Protected viny on dash and door with plastic sheets, although metal sheet or even cardboard would do.
    Then door fell open and removed screws holding inner plastic panel, then removed three screws holding latch mechanism. The problem was the pot metal pin that releases the latch had sheared. I removed the silver metal casting and drilled hole in base where original pin attached. Then I screwed in metal screw (self tapping slightly larger than hole (about 1/16 in diameter. or so) to replace broken pin, cut and ground flat end, and and adjusted its length by turning into the now tapped hole. Test fitted the assembly, re-adjusted the screw, then put all together and worked great.
    Pulled grey felt lining in glove box, and removed remants of cut wire loop. Made new one from coat hanger wire (slightly smaller than original, but worked fine), and shaped it to match original. Screwed new loop in place, and replaced box liner. Then test fit door to engage loop. Bent loop inward and up until door fit just right, and stayed closed without any rattle.
    Jake of Sigourney
    New Member
    New Member
    Postby robert213 » 09 Apr 2006, 19:42
    search keywords: r213faq slater real glove box glovebox repair
    http://volvospeed.com/vs_forum/index.ph ... opic=39803
    http://volvospeed.com/vs_forum/index.ph ... opic=41450
    [quote name='Slater' date='Jan 31 2006, 12:56 PM' post='512703']
    OK, making a new steel part to address this problem was not economical, so I detailed the procedure to reinforce the stock part so it will not break. You can also use the same procedure to repair the part after it has already broken.
    It's very easy to do - a 2 on a scale from 1 to 10. Total cost $0.99 and is enough to do 4 gloveboxes (or $0.25 to fix my glovebox; however you want to look at it).
    Tools/Materials needed:
    - Phillips screwdriver
    - Dremel
    - Cutting and sanding bits for Dremel
    - 1/16" drill bit, 3/32" drill bit, 1/8" drill bit
    - #6-32 tap
    - #6-32x3/8" socket head screw (available at any hardware store)
    http://quickbrickmotorsports.com/bay19/ ... /step1.jpg
    Step 1. Remove the glovebox door piece that houses the latch mechanism. On the door you just removed, take a look at how all the springs and pins and arms and stuff are laid out and oriented. You'll need to remember when you go to put it back together.
    Step 2. Unscrew the brown triangular shaped latch piece in the center.
    Step 3. Carefully pry off the small c-clip holding the latch pin to the frame.
    http://quickbrickmotorsports.com/bay19/ ... /step2.jpg
    Step 4. Remove the latch pin. The small post is what breaks. Mine was not broken, but I was not going to wait around until it did.
    http://quickbrickmotorsports.com/bay19/ ... /step3.jpg
    Step 5. Using your Dremel, remove the small post using a cutoff disc or wire snips or something. I then sanded what was left of the post down as low as I could go. Don't sand too much because you have to know exactly where the post was to center your drill bit.
    http://quickbrickmotorsports.com/bay19/ ... /step4.jpg
    Step 6. Drill a small pilot hole in the center of where the small post was using the 1/16" drill bit. Then enlarge the hole using the 3/32" drill bit. Finally, enlarge the hole using the 1/8" drill bit.
    Step 7. Carefully tap the hole using the #6-32 tap.
    http://quickbrickmotorsports.com/bay19/ ... /step5.jpg
    Step 8. Sand a small curved relief into the large head of the latch pin to allow the socket cap screw's head to clear. Then insert the socket cap screw and tighten. A dab of loctite isn't necessary but won't hurt for the extra piece of mind:
    http://quickbrickmotorsports.com/bay19/ ... /step6.jpg
    Here is what the completed latch pin should look like:
    http://quickbrickmotorsports.com/bay19/ ... /step7.jpg
    Step 9. Install the completed latch pin back into the frame, replace the c-clip, and finish putting everything back together the way it was taken apart.
    [/quote]
    robert213
    Forum Member
    Forum Member
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: benrk, Fish stick88, JDS60R, Marcobrick, wheelsup and 77 guests
