850 GLT add a turbo?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
ccsct203
Postby ccsct203 » Sat Mar 26, 2005 5:13 am
can I add a 97 turbo and exhaust manifold and a intercooler to a N/a 93 glt and run low boost without changing the computer or the air flow setup? I know some install work has to be done but is there a oil and a coolant supply line to tap into?
my car is mint and the mods for handling and brakes have been done.
the exhaust will need updating also. all I want is added power, not to add 100 hp.
please help.
[email protected]
Guest
Postby Guest » Mon Apr 25, 2005 10:42 pm
buy a turbo or a t5r
tatty
Postby tatty » Fri Apr 29, 2005 4:59 pm
If you just want some added power buy a chip...it's alot cheaper and easier. You're better off just buying a T5 if you want a turbo.
ac102nv
Postby ac102nv » Sat Jul 09, 2005 2:59 am
Who makes a chip for a '93 N/A 850 GLT....I've searched a little and only find them for turbo cars...any help would be great.
krepotkin
Don't waste your $$$$
Postby krepotkin » Thu Sep 08, 2005 5:09 pm
I went through all of this already with my slow 1995 850 GLT. I tried locally, nationally, and everyone told me the same thing... it would be way too expensive to put a turbo in the car. it can be done, but unless you are planning on doing it yourself, dont waste your time (especially if the car is an automatic). I recommend a nice T5 or R model. or why not a nice 740 turbo...plenty to do to those.
Tom
1990 740 Turbo M/T (yeah I know)
1988 740 Turbo 16psi, 4inch custom exhaust, cold air intake.
adrianpike
Re: 850 GLT add a turbo?
Postby adrianpike » Fri Sep 09, 2005 6:12 pm
ccsct203 wrote:can I add a 97 turbo and exhaust manifold and a intercooler to a N/a 93 glt and run low boost without changing the computer or the air flow setup? I know some install work has to be done but is there a oil and a coolant supply line to tap into?
please help.
[email protected]
I don't know for sure, but if you're interested in pioneering, go for it. As long as you monitor AFRs (with a wideband, not a narrowband), and possibly EGT's as well, it'll be safe. I'm not sure if the NA blocks have a convienient oil supply, and I'll expect you'll have to drill and tap your own drain.
I would advise some form of AIC as well.
I'll take a look at differences in the engines in VADIS and get back to you if I find anything interesting.
-Adrian Pike, Adrian Technologies
'78 16 Valve 245DL
Jos70
Turbo on a non turbo
Postby Jos70 » Tue Dec 13, 2005 1:22 pm
Anonymous wrote:buy a turbo or a t5r
Here is my reply.
Normal 144 hp and now 320 hp!
I say go for it! :D
ccsct203
Its Done
Postby ccsct203 » Sat Jan 14, 2006 12:57 am
Well the turbo is in and so is the intercooler, the water injection system, the 2.5 inch cat back....plus much more.... 10.5:1 still.... quick car
matthew1
Site Admin
Year and Model: 850 T5, 1997
Flag: United States of America
Postby matthew1 » Sat Jan 14, 2006 4:29 am
Post some pics.
Please buy from MVS sponsors. It keeps this site on the web.
Like this spam-free, organized forum? Thank a moderator.
Thanks for choosing MVS!
How to help MVS.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace
Return to “Performance, Tuning & Aftermarket”
Who is online
Users browsing this forum: No registered users and 4 guests
