IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    Chek engine codes? P0013- and P1332
    Help and Advice on S80 Volvo cars.
    Postby ajo » 02 Dec 2005, 05:58
    Hello tech what up! :o
    I pull this codes from my 99 s80 t6 today. I don't Have a clue what this condes reprecent please help.
    Code 1
    P0013 Malfuction Position
    Camshaft Position Actuator B- Bank1 Circuit Malfuction/Position
    Code2
    P1332 Mancfacurer control
    Ignition System / Misfire
    Thank you for the information
    ajo
    Postby guest » 08 Dec 2005, 04:21
    I'm not a tech, just a DIY guy. I stongly recommend a source like ALLDATA (online subscription - $25/yr, well worth it in my opinion), which explains the codes and gives step-by-step diagnotic/testing/repair information and procedures. There is much more information there, but here's some basic DTC information.
    P0033 (OBD II) = ECM-6440 (Volvo DTC)
    This code is apparently stored if a fault in the signal cable to the camshaft reset valve is detected
    P1332 (OBD II) = ECM-644A (Volvo DTC)
    This code appears to be srored if the camshaft is not in the correct position. The engine control module (ECM) registers this as a fault as soon as the engine is started.
    or
    The camshaft position (CMP) sensor flanker is not correct in relation to the engine speed (RPM) sensor.
    or
    The camshaft does not rotate quickly enough in response to the control signal.
    Some possible sources include:
    - Faulty camshaft position
    - camshaft belt has jumped out of place on the cogs
    - defective reset valve
    - mechanical fault in the Variable valve timing (VVT) unit
    - defective camshaft position (CMP) sensor
    I hope that helps. If this is jibberish to you -- best take it to a good shop.
    guest
    Re: Chek engine codes? P0013- and P1332
    Postby Woody59 » 10 Jul 2009, 18:35
    Just went through this on my '99 S70 GLT. The P1332 indicates that the CVVT solenoid is going bad. Based on the engine rpm it sends a signal directly to the ECM module. The P0013 says that there is no signal.
    Since there's no real way to test the CVVT make sure all else is checks out before buying the CVVT valve. Also note the posting on how to replace the CVVT valve.
    For reference, the green/orange wire is pin 1 on the new solenoid and yellow brown is pin 2. On the new solenoid there is a connector included in the kit that has the pin markings. Similar to posting on replacing the valve, this connector is a pain in the but so I just plugged the wires directly onto the solenoid and filled it with silicon.
    Hope this helps.
    Woody59
    Model, Year: S70 GLT 1999
    Postby dcarlson12 » 10 Jul 2009, 22:58
    To Ajo,
    Did you get some message such as check engine or ?
    i.e. what made you realize you needed to pull the codes?
    Thks.
    dcarlson12
    Forum Member
    Forum Member
    Model, Year: 1999 S80 T6
    Postby Woody59 » 11 Aug 2009, 02:53
    Ok, I am not the original poster on this but I will share what I've learned. Oh and buy the way, the dealer wanted $600 to tear down the to the timing belt. Rip off.
    Yes the CEL light comes on.
    According to Alldata, these two codes indicate that the ECM is not sure when to fire. Possible causes, the timing belt jumped a tooth (unlikely unless you've never changed the belt every 100k miles) or the crank sensor is bad. Again, could be but I'd look first at the CVVT valve. There is no way to trouble shoot it however it is the main input to the ECM for engine ignition. The problem is so common now that Volvo is rebuilding the units.
    If you get the 1332 code, I'd look first at the CVVT valve. Easy fix.
    Woody59
    Postby trev0006 » 12 Jan 2010, 21:07
    Thanks for the info.
    [quote="Woody59"]Ok, I am not the original poster on this but I will share what I've learned. Oh and buy the way, the dealer wanted $600 to tear down the to the timing belt. Rip off.
    According to Alldata, these two codes indicate that the ECM is not sure when to fire. Possible causes, the timing belt jumped a tooth (unlikely unless you've never changed the belt every 100k miles on your cars) or the crank sensor is bad. Again, could be but I'd look first at the CVVT valve. There is no way to trouble shoot it however it is the main input to the ECM for engine ignition. The problem is so common now that Volvo is rebuilding the units.
    If you get the 1332 code, I'd look first at the CVVT valve tire. Easy fix.[quote]
    trev0006
    New Member
    New Member
    Model, Year: 98 volvo
    Return to Volvo S80 Forum
    Who is online
    Users browsing this forum: No registered users and 22 guests
