IPD Volvo parts specialistsVolvo PartsVolvo Country sells genuine Volvo parts
Volvo Parts
Need Help?
Please read the Help Page. Then read the forum FAQ. Find information in the Volvo Repair Database, or browse the Volvo parts or Volvo cars pages.
Recharge that AC!
AC rechargeGet an AC recharge kit delivered to your door... to go along with all the super AC fixes and DIYs here. AC problems & fixes, Repair Database items tagged "AC"
Fast Fridays
Fast Fridays: Volvo Tuning Explained Fast Friday is our weekly performance column written by famous Volvo tuner Robert "Lucky" Arnold! Yea!
Extra Hands?
We've got a forum where you can sign up as a volunteer helper in your city/region. Or if you're on the other side of the coin, browse for a volunteer to help you.
Performance Advice!
Tune My Ride!
Need Tires?
Tires for Volvos
Extended Warranty?
I had an extended warranty at the right time, and it saved my bacon. Carchex sells them, and MVS has partnered with them.
Tool Co-op
Details
    MVS Login
    Register - it's Free!
    Get Help
    Please read the Help Page. Then read the forum FAQ. If you've tried those and still have a question, please contact Matt.
    Volvo Parts
    Please donate to the MVS moderators
    Buy anything at Amazon.com, help MVS... use these links Everything - Automotive
    Or use MVS' TireRack.com Specials links [?]
    How to read your actual miles from the ECU
    Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
    Postby MadeInJapan » 14 Mar 2006, 04:39
    Someone try this and if it works, please, Matthew, put this in the Database:
    As long as you have the DTC boxes up under the hood ('93-'95).
    1. Switch ignition on
    2. Connect the fly wire to socket - A7
    3. Push button 5 times
    4. When LED comes on and stays on, enter code 1-1-1 as follows:
    - press the button once when LED is still on
    - wait for LED to go out and come on again
    - read off response, which will be the last three digits of the odometer miles
    5. Repeat steps #3-4, but enter code 1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles. If you have less than 100,000 miles, the first digit will read as 10 blinks.
    94 850 Sedan NA Drk Blue/Tan
    '00 V40 Purple/Grey Mobil-1
    Model, Year: '98 S70 T5
    Postby pmonk » 14 Mar 2006, 19:07
    I had to post and say I think this works. I have a 94 850 and it read off about what I should have as my odometer busted a while back. Very handy! All zeros seem to be ten blinks. no matter what position they are in. Thanks!
    pmonk
    Forum Member
    Forum Member
    Postby skyman » 04 May 2006, 17:44
    It woeks.
    skyman
    Postby MadeInJapan » 05 May 2006, 01:09
    cool man! This is great if you get a car with a broken odometer and need to know actual miles...probably other reasons to find the true miles.
    Btw, I've been out of country for about a week...back now so I'll be active on this board again.
    Postby pebsham » 17 Sep 2006, 15:40
    Interesting this one. I own 3 850 Estates (Wagons) and all are pre 1996 with A + B Sockets under the bonnet. I reset the service light on the 1994 2.0 manual from socket A7 as described and all went fine. I found out that you can check the true mileage from these sockets and while I had the bonnet open I read them from A7 mileage was 38 miles out from the dash odometer which isn't bad over 134,000 miles. All good stuff.
    I have a 95 2.4 auto with documented mileage of 81,000 and thought I'd check it.
    I put the ignition on and put the flylead in A7. Pressed the button 5 times (each time the led lit up) as told and waited for the LED to respond. It never did. I then tried the service light reset trick of pressing the button once to get it into the correct mode. LED lit up once but never stayed on.
    I have a high mileage 95 and tried the same thing on that one and got the same result, nada.
    Any idea why I can't get these cars in A7 dignostic mode? I've tried other checks such as A6 and the codes read 1-1-1 as expected so the block is getting power etc. Anybody come across this? It seems strange that out of 3 cars only 1 works as supposed to.
    Thanks in advance
    pebsham
    Postby MadeInJapan » 17 Sep 2006, 15:58
    When we had an 850 with the black boxes ('94 was ours) I found that it was the speed of which I pressed the buttons that made a difference...don't know why, but I had to press the buttons very very quickly....so I practiced and got a rhythm before pushing the buttons to reset the service light. Could be a similar issue with yours. Give it a try and see if that makes a difference. Don't take your time...get a rhythm in order to push the buttoms quicker.
    Postby petershen1984 » 29 Oct 2006, 19:24
    Wow... let me try this on my 960 and see if it works. My odometer was replaced before and currently reads 016,000 miles ;-)
    Peter Shen
    1992 Volvo 960 (Silver)
    petershen1984
    Forum Member
    Forum Member
    Postby MadeInJapan » 29 Oct 2006, 19:42
    Don't know if it will work on a 960...please try and if it works, post back here as well as you discovery over on the rwd section. I'm sure others would like to know as well. :o
    Postby myalex » 25 Dec 2006, 20:02
    Sorry for my english; I am an italian.
    I have an 850 GLE estate ('95) but i have try to my car and don't work. I have follow step by step the procedure but nothing in the display. I have try to read from ECU the error from the ECC - ABS - ENGINE with the instruction in the Hayes Manual but don't work. Something may help me ?
    Bye
    Alessio
    myalex
    Postby MadeInJapan » 26 Dec 2006, 01:09
    You need to clear other codes before you start tying to read mileage. Download the free service manual....It will be good for your English practice and also learning about your car.
    Postby myalex » 26 Dec 2006, 16:39
    thank's. Tomorrow i try to reset all code and read the mileage from ECU.
    Please where i found the free service manual?
    Bye
    myalex
    Postby myalex » 26 Dec 2006, 16:53
    sorry, i have found the manual. I am in error because I thought to read the codes of error in the display of the dashboard. If I have understood well, I must read the sequence of flashes of the
    led, just?
    myalex
    Postby MadeInJapan » 26 Dec 2006, 17:09
    That is correct, you must read the lights blinking.
    If you take the odometer out you can set it to match the correct mileage, but I would read the mileage a few times first to make sure it is correct.
    There is a good write-up on how to advance the mileage on the odometer with the use a pencil and drill.
    Postby fredstock99 » 28 Mar 2007, 05:40
    I got a 1993 850 GLT, and I just tried this and here is what I got... Just wondering what it means.
    After pressing 5 times, and entering code 1-1-1 according to step 3,4 of original post, i get this response "10-3-1" ... After entering code 1-1-2, i get "1-10-6." if i understand this correct, the 6 digits of my mileage read as "1,10,6,10,3,1". Is this correct, and what does that mean? My odometer was broken for about 4 months until i found a used instrument panel and just swapped the whole thing.
    1993 850 20 Valve 5 cyl : had 190k miles when i joined this forum : nor cal - so cal - long island. Now i live in NYC, its got 259k miles, and sadly, the only car I've ever owned is going to be scrapped. RIP Black Volvo. You will never be forgotten.
    fredstock99
    New Member
    New Member
    Model, Year: 1993 850 GLT
    Next
    Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
    Who is online
    Users browsing this forum: Bondo1, Google [Bot], wheelsup and 102 guests
