Help and Advice on Volvo's extremely popular car line, powered by Volvo's nearly indestructible, versatile inline 5-cylinder engine.
by MadeInJapan » 08 Apr 2006, 18:40
This is for a '98 T-5. Others will vary but the same or similar to most 850 turbo's. The designed changed with later S/V/70's so be aware. I got so darned frustrated trying to see this intsy bittsy diagram under the hood of the car, so I finally took a decent digital picture today. I hope it helps others. Just copy it and keep it on your computer. It should be a good reference.
94 850 Sedan NA Drk Blue/Tan
'00 V40 Purple/Grey Mobil-1
- Model, Year: '98 S70 T5
by 95autoturbo » 09 Apr 2006, 05:02
yes......It is an 850!
95autoturbo
- Forum Member
by MadeInJapan » 09 Apr 2006, 05:35
We can post that diagram too!
by Ghassan » 12 Apr 2006, 17:55
hi,
Can someone point out what the mini air filter is for. There is a large one on the left side of the screen (I believe for air intake) and there a small one on the bottom right side of the picture. What is the small one for?
thanks.
ghassan.
98 S70 T5 Auto
03 540i 6sp
Ghassan
- Forum Member
by MadeInJapan » 13 Apr 2006, 00:45
Good question...I was wondering the same thing. If you really want to know, follow the line (actually hard to get to...runs under battery) from the purge valve and see where it goes...actually might go to the same air filter???
by STORMY » 12 Aug 2006, 01:57
can a hole in the vacuum hose cause the air to blow out the side vents and not the middle ones?
CARRIE 780 BERTONE TURBO
NEED HELP PLEASE!!
STORMY
by MadeInJapan » 12 Aug 2006, 03:13
Are you talking about Air Conditioner in the cabin? If so, then no, this has nothing to do with that. Instead, you may have small motors in your vent system itself that opens and closes the flaps, and they may be broken, or dirty and not able to move properly. There are probably other reasons too...not familiar with your car either....sorry.
by Volvo_240_Atari_2600 » 08 Oct 2007, 04:27
Just came across this older thread.
I finally bought the 98 v70 Non-Turbo wagon I had mentioned in an earlier thread. The car id nice and I was able to talk her down and we settled for $2,500.00 based on the need of a timing belt (complete) and possible CV Joint or Spring Seat on passenger side, not to mention it was low on 3 qts of oil, but no aparent leak from the rear main seal... The leak was from the oil filler cap that was not sealing well... My 240 did that and the trich was a $10.00 cap.
Anyway...
I washed the engine compartment today since it was filthy... Oil leaked over time from above (oil filler cap) and in the bath... the high pressure of water took out one vacum hose and I have no clue as to where it connects.
I will see if I can get a pic tomorrow to show you guys to help me ID where it goes.
Description of where I am sure it comes from:
Just at the back of the air filter box and facing the driver are two vacum pegas that come from the filter box... The lower vacum line is still conected and the rubber elbow looks OK but could be replaced... It's the one on the top...
The top elbow was brittle and could not take the pressure of the water and gave way... Now I have a line of about 10-12" long and I cannot find where it would have conected to.
Can someone tell me where that line goes on the 98 v70 non turbo?
NA car if that helps.
Doing the T Belt etc... next Saturday and today the car now runs like crap after the wash. I did get water in the distributor cap so I had to open it and dry it out to start...
Car started but the guy at AutoZone said the scanner read a fault code of "Misfiring" which was taken before the engine wash and before that it ran smooth even with the CEL light on which I thought could have been the 02 sensor.
But now, it runs like it is misfiring and from the looks inside the distributor cap, I am almost convinced that a change of plugs, rotor, cap and wires should resolve that issue.
Any thoughts?
Could that vacume line be an added culprit since the reading before the wash was MISFIRE but it ran smooth before the wash.
Thanks
- Forum Member
- Model, Year: 89 245 GL
by chuckcintron » 08 Oct 2007, 13:27
Be sure to do the PCV rebuild. Many of your oil leak issues will be solved by that repair.
Man, you are brave taking a high pressure wand to your engine
Also, thread hijacking like this makes it tough for folks who may search the forum in the future to find information learned in this thread. Might have been better to start a new thread...
-Chuck
chuckcintron
- Forum Member
by kenborn » 15 Aug 2009, 17:09
Can you provide the picture of the vaccum hose please
I have a 98 s70 T5 changed the engine and don't remember where the hoses connect to.
kenborn
- Model, Year: S70 T5 1998
by matthew1 » 15 Aug 2009, 18:45
Imageshack -- who was hosting the diagram -- appears to have deleted it from their server(!).
I found it somewhere, and am now hosting it here for safekeeping.
Please buy from MVS sponsors. It keeps this site on the web.Thanks for choosing this Volvo Forum to get your Volvo info.Like this spam-free, organized forum? Thank a moderator.
1997 850 T5
matthew1
- Model, Year: 850 T5, 1997
by rcannon » 21 Nov 2009, 01:16
Hello - thanks for the diagram. I'm new here. Great forum. I have a new 97 850 turbo wagon, and am having some problems with overboost and cutting out. I can't figure out where the red line that comes out of the TCV should go. Currently it's tee'd into a line that hooks onto the beginning of the air inlet tube just after the air filter, and the other end goes to the end of the air inlet tube where there is a larger hose also coming into it. This doesn't make sense to me- the wastegate needs a line going to boost pressure. But I can't find a pressure tap according to the diagram on the turbo, unless the large 3/8" or so braided hose going into the turbo inlet line comes from the inlet manifold and there's an orifice in there or something.
Also the center blue line was going to a metal tube about 1/8" dia going down the back of the engine along a larger metal tube, and the hose appears about 1/4" so that can't be right. It says it goes to fresh air hose, or I suppose that's the air inlet also.
Thanks in advance.
Bob
rcannon
- Forum Member
- Model, Year: 96,7 850 T, GLT Wgns
by rcannon » 21 Nov 2009, 01:36
Found a better picture elsewhere and mine is way off as suspected. But I still don't know what goes on the hard 1/8 tube that starts near the TCV but lower, and is rigid mounted, and goes across and down the back of the engine lower somewhere out of view. Maybe to the transmission? If so what should be hooked to it?
rcannon
- Forum Member
by kcodyjr » 01 Mar 2010, 08:02
Have that better picture? I'm finding that one hard to follow.
1997 850 GLT sedan, 152K and WHOOHOO!
RIP 1996 850 wagon, 201K, hit by a runaway 4-wheeler
RIP 1996 850 GLT sedan 5spd, 260K, rearended someone
RIP 1986 245 boring, 200K, rusted beyond inspectability
RIP 1981 242 turbo 5spd, 300K, serious teenage crash
kcodyjr
- Forum Member
- Model, Year: 1997 850 GLT
Return to Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)
Who is online
Users browsing this forum: 98volvotank, Franz47, Google [Bot], Marcobrick and 81 guests
