Oil leak around turbo
dang5001
Postby dang5001 » Mon Jul 24, 2006 1:50 pm
I have a 99 S70. I thought the oil return line on the turbo was leaking, but it wasn't the problem. It now looks like the leak is coming from someplace in the area where the fresh air intake enters the turbo. It isn't leaking that much, but I don't want it to become a problem. Could a clogged PCV cause the leak in that area? Any help or suggestions are appreciated.
Thanks in advance.
pfeener
Postby pfeener » Mon Jul 24, 2006 3:25 pm
It's normal for the underside of the turbo to have a little oil on it. If it doesn't leak enough to make a mess or drip on the floor, I wouldn't worry about it.
dang5001
Postby dang5001 » Mon Jul 24, 2006 4:37 pm
It is starting to leave some oil on my garage floor. Not that much. However, if it is a symptom of something bigger, I want to try and fix it.
Thanks for the reply.
White850Turbo
Postby White850Turbo » Mon Jul 24, 2006 7:30 pm
Pictures would be a great help in diagnosing what the issue may be here.
-Sean
1998 S70 T5 (Almost Stock)
dang5001
Postby dang5001 » Fri Aug 04, 2006 11:22 am
It was the flame/oil trap. PCV was clogged. had it replaced and all is fine.
Flag: United States of America
Postby MadeInJapan » Fri Aug 04, 2006 3:13 pm
I know you changed out part or all of your pcv system, but check the following too:
There is a bayonnet connector at the lowest end of the air-intake hose (the accordian one) to the turbo. Attached to this is a hose that goes to the oil separator (part of the pcv system) under the intake manifold. If that line or the valve in the bayonnet connector gets clogged up, then the spill over dumps right on top of the turbo and if there's enough, will drip down on the floor. Be careful disconnecting the connector there...it's plastic and you can break it. Once the small hose is off of it, make sure it's not clogged. Use a pipe cleaner with brissles dipped in alcohol to thoroughly ream it out. I had the same problem and had to clean this valve out when changing out my pcv hoses. Maybe you already did this with your pcv maintenance, but I wrote this just in case you didnt' check the valve mentioned above, as it's often over looked.
dang5001
Postby dang5001 » Fri Aug 04, 2006 3:21 pm
Thanks. I'll check it this evening.
awbooth
OIL COMING FROM TURBO AREA
Postby awbooth » Tue Mar 27, 2007 8:25 pm
I have the same exact leak that has sorrounded the clamp that goes around the air intake hose on my 1999 Volvo V70 XC. I have no visual on reaching the PCV Valve area. The brake cylinder is in my way and I have no way of seeing the bayonnet connector mentioned in someone's response. Thanks for your help. Also, anyone familiar with the viscous coupling problem I have.
driver60
Oil coming from turbo area
Postby driver60 » Thu Apr 19, 2007 9:00 pm
I have a 98 S70 T5 with 60,000 miles. I am trying to disconnect the "bayonette" connection where the PCV line meets the air inlet to the turbo. I cannot find a position where the plastic piece will pull out. Any suggestions?
Postby MadeInJapan » Thu Apr 19, 2007 10:25 pm
Take the entire accordion hose off of the turbo, take it out of the car and then disconnect the bayonet connector. This is the only way that I was able to do it...otherwise, even if you get the connector out, you'll have mega issues trying to reseat it.
Return to “Volvo 850, S70, V70, C70 & V70-XC Forum (1992-2000)”
Who is online
Users browsing this forum: Bing [Bot] and 75 guests
