Gas Tank Removal Question + Leak photo
Gas Tank Removal & Leak Fix Tutorial
1. Disconnect the negative battery cable for safety. 2. Block the front wheels, jack up the rear, use some jack stands to hold up the rear. 3. Remove the floor board to open up the area to access the top of the fuel pump and sender.
Date November 11, 2009
2 responses to “Gas Tank Removal Question + Leak photo”
  1. tom says:
    why is it so hard to figure out which fuel pump is on a 1995 940 wagon b230f non turbo?
  2. ebi says:
    how i can do to repair fissure in tank plastic volvo 940
