November 8, 2009
How to Change Battery in Remote Entry Key
1. Open the remote control by twisting a coin in the ring between the front and rear sections (leave the ring in place). 2. Replace the battery, with the plus-side upward (see illustration). 3. Reinstall the cover, making sure it is secured tightly.
how to change battery in remote entry key
3 responses to “How to Change Battery in Remote Entry Key”
  1. David says:
    How do I open the keyfob of a 2008 s80 to change the battery?
  2. frank says:
    don’t know how or can’t figure out how to open key fob case to get to the battery 2007 s80
    to replace the battery ??
  3. freddy k says:
    Remove the valet key from the fob and behind it is a small Phillips screw. After that the fob will split and the battery is visible.
