How to Change Starter Motor S40 & V40?
MVS » Volvo Repair Database » Electrical, Battery, Fuses, Relays, ECU, Starter, ABS module, Alternator, Modules » How to Change Starter Motor S40 & V40?
To remove:
- Disconnect battery negative lead.
- Disconnect positive lead and connector of starter relay.
- Remove three fixing bolts from starter motor. Top bolt also holds the cable support.
- Slide starter motor to rear, turn and lift upwards.
To reinstall: Transfer locating bush to new starter motor. Reinstall in reverse order. Torque bolts to 50nm.
how to change starter motor?
Related Posts
- How To Change a Starter
- Tutorial – Replacing the Starter Motor 1998 S70
- Starter Won’t Disengage
- Replacing Starter
- 850, S70, V70, V70XC Front/Rear Motor Mount R&I
