Volvo Repair Database
How to Maintain Your AWD Volvo’s Driveshaft
For all AWD Volvo Models
Volvo XC70 AWD propshaft joint lubrication
MVS Forum member Jimmy tells us explicitly how to make your AWD Volvo system go well over 100k miles. If you’re reading this with 150k+ miles on yours, and you haven’t “done anything” to extend the AWD system’s life, you’ve probably been kind to your driveshaft, for instance keeping all 4 same brand / same tread depth tires on her (for 1st gen AWD Volvos), or you’ve driven gently, or you’re lucky.
But if you hear chirps or a bumping noise on acceleration, it will progress to a vibration when the joint gets dry and balls wear and joint fails.
The driveshaft from angle gear to viscous coupling needs to have the CV joints lubed by 100K miles or there is a great likelihood you will end up replacing the whole shaft assembly or at least the front joint if available.
It is not a hard job but there are precautions.
Read this VRD article for some tips & tricks on maintaining the AWD system on your AWD V70/S70.
Read the rest: Volvo AWD Maintenance Procedure DIY
photo credit to holler1
  1. Front Driveshaft Removal V70 XC
  2. Front Driveshaft Remove + Replace
  3. Volvos Expensive To Maintain? Pros & Cons
  4. Pre-2001 Volvo XC70 AWD Drive Shaft Removal
  5. AWD issues – Diagonosing bad propshaft in XC70
Tags
Bookmark permalink
One Response to How to Maintain Your AWD Volvo’s Driveshaft
  1. Barbara Dumais says:
    I drive a 2006 Volvo S60 AWD with 56,700 miles on it. One tire cannot be repaired. When I replaced all four tires a couple of years ago, I purchased road hazard and I was told that if needed in the future all four tires would be replaced without charge. Now the company is telling me that because the remaining tires have > 50% tread remaining that it’s only necessary to replace the one damaged tire. Is this true? My understanding was that this could result in damage to the transmission. Please advise. Thank you.
