Volvo Repair Database
Important Information on Ecu issues (850,S70 series)
Q: “How do you open the module box? I’m not sure and don’t want to break it. Thanks. ”
A: To open the control module box first locate the two clips at the left and right of the control module box cover, then putting a screwdriver or your finger under the metallic clip and pull it the left, then pull the right clip to the right to remove the cover but I recommend you to use a screwdriver to remove the clips easily to free the cover.
note: before removing any of the control modules make sure the ignition is off and least 10 minutes of time has passed.otherwise you might damage the control modules easily.
  1. Where to Send Your ABS Module
  2. Replace Distributor Cap & Rotor Volvo 850, S70, V70
  3. Replace Trunk Struts Tutorial
  4. How to Remove/Clean Volvo SC-810 Radio
  5. Brake Pad and Rotor Job Checklist & Tutorial
This entry was posted in Electrical, Battery, Fuses, Relays, ECU, Starter, ABS module, Alternator, Modules and tagged , . Bookmark the permalink.
