Volvo Repair Database
Interior bulb designation, sizes, etc.
Several of my radio lights were dead and I replaced them following the great bulb tutorial instructions.
I went the Radio Shack route ($1.69/pkg of 2 bulbs #272-1092) and replaced all 5 bulbs for $5.40 – you know the others will die soon enough so do’m all). The OEM bulbs are in a black plastic case that can be reused while watching a CSI episode on TV.
1. Using a razor, carefully cut the melted “mushroom cap” that holds the wire lead that is wound through the base. With my glasses off, I have great microscopic vision!
2. With the tip of the blade, gently pry the wire away from the side of the case and unwind it. Note how it is wound twice around the base – you’ll be putting the new one in the same way. Repeat with the other lead.
3. Pull the bulb from the base and twist or push the blue cover off with your thumbnail.
4. Carefully push the blue cover over the new bulb, insert bulb in base.
5. Pull the wire leads tight and wind each twice around the indented area of the base. I didn’t solder mine. I just made sure the wire was tightly pushed (small jewelers screwdriver works well) into the circular channel at the top of the base.
  1. Front Corner Lens &/or Bulb Replacent
  2. Volvo Radio Light Bulb Replacement 816
This entry was posted in Interior Lights, Mirrors, Radio, Speakers, iPod Input, Antenna, Volvo 850, Volvo S70 & V70, 1998-2000, Volvo XC70 & V70XC and tagged . Bookmark the permalink.
