Remote Keyfob Programming Help
and
More Remote Keyfob Programming Help
Turns out the Tailgate Lock on a wagon seems to be the center of attention when you arm your locks etc…
MVS » Volvo Repair Database » Keys, Remotes, Keyless Entry, Locks, Ignition Switch » Remote Keyfob Programming Help
and
have done this. press pad turn key on and off six times job done frank
just to be a bit more specific hold the lock button down on the remote insert key turn to the on position the first click then off do this 6 times in total while holding button on the remote after 6th time take key out and press lock then unlock back and forth to make sure its working!
take the key out take the key out i repeat!
have tried that with no avale
got aa to fix the problem
So, what did they do to fix the remote?
