Volvo Repair Database
Replace Trunk Struts Tutorial
Replace Trunk Struts: A How To
Changing lift gate struts on a wagon is a little more involved but still fairly easy. These insructions are for an 850 but should work on a 98 wagon.
1. Remove the courtesy light in the center of the rear roof trim by prying it out with a small screwdriver.
2. Disconnect the wiring and set aside the light.
3. Remove the roof trim by prying out the the two plastic caps and removing the two screws under them with a #25 torx driver.
4. Remove the rear pillar & roof trim by prying out the trim caps and removing the screws. Gently release these panels by pulling them free of their retaining clips.
5. Support the tailgate with a prop. Change one side at a time.
6. Disconnect the strut to body bracket. The strut ball-joints will pop out using a suitable pry bar.
7. Installation is the reverse.
  1. Brake Shims Fix 850, S70, V70, XC70 Squealing & Noise
  2. Odometer Fix Tutorial
  3. Strut Replacement: A How To
  4. Replace the evaporator in an 850
  5. Replace Your Thermostat: A How To
This entry was posted in Interior, Seats, Dash, Remotes, Switches, Interior Bulbs, Latches, Mounts, Clamps, Hardware, Bushings & Fasteners, Volvo 850, Volvo Repair Database, Volvo S70 & V70, 1998-2000, Volvo XC70 & V70XC and tagged , , , , , , , . Bookmark the permalink.
