September 30, 2010
New Grille, Headlights and Foglights
How to Freshen Your Volvo’s Look with Jewel Headlights
S70 front end freshening: grille and lights
Who says you’re stuck with the way your 1990s Volvo looks? Take a look at Volvo Forum member georgeleedom‘s remarkable 1999 Volvo S70 front end update. This is simply an outstanding refresh. And it’s functional too: better light on the road. Details:
  • lighting came from swedishautoparts.com, genuine Volvo
  • “Tony and knocked about 20% off since I bought everything at once”
  • fogs came with the grilles, rocker switch, jumpers and relay
  • wiring is already there since they were an option for the S70
  • “instructions were very detailed”
I’m a shade tree mechanic at best, but installed everything myself in a couple hours. The vision at night is unbelievable brighter. It’s a much bigger difference than I expected. I’ve done a lot to make the car go faster and handle better. It’s nice to be able to see up the road a bit.
Read More: New Grille, Headlights and Foglights
One response to “New Grille, Headlights and Foglights”
  1. […] money for the substantial, classy jewel headlight + egg crate grille freshening? Try this much-less-expensive job. I started out wet sanding with 600 grit and then […]
