December 6, 2008
New Modified Transmission Flush Method with Pictures
The tools required are few: Along neck funnel to access and reach the dipstick and transmission filler tube, a 15/16 or 24mm box/open end (not a 1/2″ drive ratchet since it will not fit between the drain plug and the rear brake fluid lines), 5-6 feet of 1/2″ I.D. clear tubing (5/8″ID will be too wide), snap-ring pliers, and a 6″ electric zip or cable tie for added security after replacing the transmission line clip when you are finished. In addition, a new crush washer for the ATF drain plug (same size as the oil drain plug) and a drain pan will be needed.
Trans fluid flush tools
Trans fluid flush bottle
Tags 850, C70, S70, Transmission Fluid Flush, V70, XC70
3 responses to “New Modified Transmission Flush Method with Pictures”
  1. adventurer2112 says:
    HI All,
    2 mechanics said MY 1995 850 tranny was shot. Volvo repair shops said its too bad< i need to drive it till it dies and pon up for a used tranny. Car would shudder and not go into 1st gear without the shudder. Hard time shifting from 3rd to 2nd also. Would put tranny into neutral coming to a stop sign and while waiting to go, made terrible noises.
    Did the flush as recommended here, except used std DEx 3 fluid.
    Flushed between 19 and 20 quarts.
    Transmission is working as well as it has since I bought it at 125 K. THANKS to all of you so much.
    Blessings
    Jack
  2. Fred Coyle says:
    Pretty easy and effective transmission flush proceedure that fixed my 2002 V70 auto trans shift problems.
    1. Drain trans from plug into pan (appox 3 quarts)
    2. Refill with 3 qts Mobil 3309 Trans fluid.
    3. Drive 5 mile route filled with stop signs to exercise/flush all pistons and clutch packs (clutch packs and pistons fill and drain through a single port, don’t flush)
    4. Repeat three times.
  3. Richard Lloyd-Roberts says:
    Did this on a C70 2004. I was experiencing hard shifts and slipping. Did it with a case of Toyota fluid IV. Works like a charm. I was told by the volvo dealer to get a new gear box!
