Volvo Repair Database
No Brakes When Cold, Volvo V70
No Brakes Symptoms
Vacuum Pump/Switch Replacement with Pics V70 P2After a startup when engine is cold there is no brake assist, the brake pedal feels very hard, braking efficiency is very low and for some reason it feels worse when driving in reverse.
No Brakes Solution
Vacuum pump and/or switch replacement
I bought the parts from FCP:
$179.55 for the Pump – 31317445
$8.99 for the Snap-on Coupling – 30744403
$59.95 for the Vacuum Switch – 31265825
No Brakes When Cold – Vacuum Pump/Switch Replacement with Pics
  1. V70GLT 2000 Starting issue – Cold or Hot
  2. Volvo 850 cermamic brakes or OEM?
  3. Brake Shims Fix 850, S70, V70, XC70 Squealing & Noise
  4. S80 Front Brake Disk and Pad Replacement
  5. Volvo 850 Heater Core Replacement Tutorial
This entry was posted in Belts, Hoses, Vacuum Lines, Brakes, Brake Fluid, Brake Lines, Brake Pedal, Parking Brake, Pads, Rotors, ABS, TRACS, Volvo S60, Volvo S60 R 2003-2007, Volvo S80, Volvo V70 R, 2004-2006, Volvo V70, 2001+ and tagged , , , , , . Bookmark the permalink.
