Volvo Repair Database
PCV Job for V70 and S70 Non-turbo
S70 and V70 N/A PCV job
Since mine is a Non-Turbo, there are minor different designs compared with Turbo Models. In addition, I will point to areas of possible problems for people.
- Read the above write-up for Turbo.
- Copy Radio AM FM channels, disconnect battery for safety.
- Remove electrical connections to Throttle and Idle Valve
- Remove these 2 hoses (my vacuum hose is brittle so I replaced it)
- The PCV connection to elbow: turn it Counter-Clockwise (when viewed end on, similar to opening a bottle cap) a bit, it will come off the plastic Elbow.
PCV check V70 non-turbo
  1. 1998 V70R Turbo vacuum line – How to get it off?
  2. Vacuum Hose Routing for ’94 850 Turbo
  3. Tightening up the Turbo Waste Gate ?
  4. Proper Boost Measurements
  5. How to Fix Clogged PCV
This entry was posted in Engine Breathing, PCV, EGR, Idle Air Control Valve and tagged , , , , , . Bookmark the permalink.
One Response to PCV Job for V70 and S70 Non-turbo
  1. Tom says:
    Hei hei leute spitzen Blog danke euch dafür und LG Tom
