Volvo Repair Database
Reclaimed Horsepower with MotorVac
The fun is back in my 850. The friendly Kathy’s Northern European Auto Repair manager Tom asked me if I’d like to run my 850 on this machine for 30 minutes. “What machine?” I asked? MotorVac Carbon Clean System. “It removes the carbon build up in your engine.”
Setup took about 15 minutes, and it was all a matter of fitting the in/out hoses from the machine to the fuel lines on my 850 T5. I run fuel treatment in the gas tank from time to time, but I’ve never done anything like this. Tom got me excited with examples of restored power and increased fuel economy.
The machine needed no prep because it had enough fuel/detergent mix in it. Once the in/out hoses were attached, it was “go”. Tom pressed the Leak Test button, and when that showed no anomalies with his setup, he dialed in 30 min. and pressed Start.
I fired the engine, that was it.
There was no coughing or sputtering. I simply idled for 30 minutes as the fuel/detergent mix was pumped into the fuel rail, injectors and engine as fuel would be from the tank. The car didn’t know the difference.
A good summary of the process is this: think of it as fuel injector treatment (like STP or Lucas gas treatment you buy at gas stations, auto parts stores etc.) times 100. The concentration of detergent is much higher, albeit for a shorter duration.
The Check Engine light was on after the procedure because one of the injectors was dislodged. Idle and power were off too. I reseated the injectors a few miles after pulling out of the garage and the idle/power issue disappeared.
Can I feel a difference? Oh yea. The car pulls harder at all RPMs.
  1. Why Too Much Power Can Be Bad
  2. How To Buy A Volvo 240 Turbo
  3. Fix your own fuel pump relay
This entry was posted in Engine, Engine Internals, Turbo, Wastegate, Air Delivery, Airbox, Air Filter, Camshaft, Valves, Head, Pistons, MPG, Fuel Economy & Trip Reports, Performance & Horsepower, Volvo 850, Volvo S40 & V40, Volvo S60, Volvo S70 & V70, 1998-2000, Volvo S80, Volvo V50 and tagged , , . Bookmark the permalink.
