Reset Service Light Volvo S40, V40
MVS » Volvo Repair Database » Electrical, Battery, Fuses, Relays, ECU, Starter, ABS module, Alternator, Modules » Reset Service Light Volvo S40, V40
S40 and V40 (1999+)
- Hold down the odometer button
- Turn the ignition so all the lights come on
- Keep holding the odometer down for 30 secs or until the service light starts flashing
- Release the odometer button while service light flashing
- Turn off and on again to check
Related Posts
- Reset Service Light – Volvo
- S80 T6 2001 Service Light Reset How To
- Reset Service Message Volvo S80
- Reset Your Service Light: A How To
- Reset Volvo S60 Time for Regular Service message
This entry was posted in
Electrical, Battery, Fuses, Relays, ECU, Starter, ABS module, Alternator, Modules,
Volvo S40 & V40 and tagged
reset service light,
Volvo S40,
Volvo V40. Bookmark the
permalink.
anyone know how to switch off the front light on a Volvo S40. there is one Trix doing that I have heard. because they are on all times.
Thanks!
yes, take out the daytime running lights fuse!
but, why?? its a very good safety feature??
The instructions are in the user manual. From memory, you place the headlight switch in the side-lights position, pull back the dipped beam stick whilst switching the ignition on, then whilst holding the stick back, move the headlight switch to either off or on.
(apologies if that is not quite right)
I have a 2008 s40 does the reset service light info applies to this year and model too??
hi, i have two problems with my s reg v40. the first is that the headlight switch is not working properly. can only get headlights on when set to 0. also the dip beam switch has to be held in place to work. the second problem is the air con. just get a green flashing light. fan will not cut in. any ideas how to fix?
The bright’s headlight switch: pull to you to flash your brights, brights go off when you release it, push it away from you and it locks in place, holding brights on. This is pretty much standard on all cars, all makes. (Only a few are different) Dated a girl college several years ago, going out on night, she complained her brights switch didn’t work, told her to push the switch forward, problem solved.
i cant find the belt for the power steering pump. does anyone know where its located?
HIGHBEAMS WILL NOT STAY ON IN YOUR VOLVO UNLESS YOU HAVE YOUR HEADLIGHT SWITCH IN 12 O’CLOCK POSTION. THEY ONLY FLASH WHEN PUT IN DAYTIME LIGHT POSTION.
I have a S40 on a 58 plate Reset Service Remider 1st time (Thank You)
1st Service From Volvo Dealer £276 after bartering with them they said they would do it for £160
I got it Done at a Well reputable Garage using Genuine Volvo Parts And Fluids For £160.
SERVICE LIGHT RESET
Ok I know that they say hold the trip button down for 30 seconds while you switch on the ignition – but that did not work on my v40.
By messing about I did manage to get it to work. The lights were in the side light position (dont know if this makes any difference)
1)with the ignition off, press the trip button and keep holding while you switch the iginition on.
2)Release within 4 seconds and re-press and hold until the light flashes and you hear a beep. (about 10 seconds)
Hey presto – its finally OUT.
I hope this works for you too.
thanks
paul
it worked! – i am so proud of myself =- thank you!
just tried this on my 2005 volvo s40 sport deisel
worked a treat!
however make sure you remove your finger from the odometer button while sevrice light is flashing!
it only flashes 3 times – so be quick!
happy days
thanks for the help , on the reset…YEAH PUDDING!
My lights on my S40 1999 work on the 0 position but not on the on position??
I followed the instructions on resetting my S40′s service light:
1.Hold down the odometer button
2.Turn the ignition so all the lights come on
3.Keep holding the odometer down for 30 secs or until the service light starts flashing
4.Release the odometer button while service light flashing
The service light went off after releasing the odometer when the light is flashing. However, when i turn the ignition off and back on, the service light is on again???
done it service ligth goes out, but switch the car off and back on the service light is back on
this was on a s40 2000
I used the instructions above and it worked perfectly. Many thanks
Just reset service light with the above info and it worked perfectly. S40 Sport 2006 Regards
2005 s40i worked perfectly. Thanks,
just reset service light on my s40 many thanks
head light on right hand side of my volvo v40 2002 is not comming on garage man said no power to it & could be fuse but he couldn’t fine the fuse for it. is there different fuse for each light ?
Hi i have just reset my service light ,it was driveing me mad thank you for your help, ian
