Volvo 850 (1993-1995)
- There are two diagnostic units(it says A and B on the cover) located adjacent to washer reservoir under the hood. Turn on the ignition and open the module A and insert the flylead into socket 7.
- Press the button on the diagnostic unit 4 times, briefly but firmly. Then the LED illuminates and stays illuminated, and the system is ready to accept manual code input. A code number for resetting the service reminder light is 1-5-1. To do this, press the test button once and release it And LED illuminates again.
- Then press 5 times and wait for the LED to illuminate.
- Press the button once and LED should flashes several times in succession and the reminder should have been reset.
- Switch off the ignition and replace the flylead in its holder and close the cover.
Looking for resetting instructions for your Volvo S80 or V40 or S40?
Reset service light instructions for your Volvo S80
Reset service light instructions for your Volvo S40 or V40
Volvo 850 (1996-1997) and S70, V70 (1998)
You need an OBDII tool that resets Volvo service light codes. See this service light reset forum thread for more. They run about $100 to 200 — or — take it in to the dealer or independent Volvo mechanic and have them do it. Call to see if they charge for this first. Note: I’ve read reports of people having success with having the local Shucks/Pep Boys/Checker auto parts store do it.
S70 and V70 and C70 and XC70
- Press and hold odometer reset button
- Turn ignition switch to Run
- After SRL flashes, release odometer reset button
- Confirm by turning your Volvo off, then on again
Register
Search
Help
Thanks to everyone who provided answers – my radio works! I wanted to post my exact steps to help anyone who still has any questions … I have a 98 S70:
With an OFF reading on my radio, I put the key to the 1 position, with all lights off but Radio ON so it read OFF (really). After 2 hours, I looked at it and it read CODE! So leaving the key is the 1 position and leaving the radio on, I input my code (which according to my dealer is a standard code for ’98 S70s – 4336 – and waited about 20 seconds and lo and behold the radio came on. I am forever in the debt of this site and all of the people who posted their answers – thank you!!
Thanks for help, it worked on my V70 ’00 !!! Service guys told that only solution is the OBDII tool…
I could not get the method to work on my 2008 C-70. I called my U.S. Volvo dealership and they instructed me that the driver door needs to be open in order for the procedure to work. I thought that was strange, but since I could not get the procedure to work before, it could not hurt to try it.
With the driver door open I did the following:
(note: My trip meter was at 0 since I tried before and failed)
1. Key to position 1
2. Press and hold trip reset button
3. Key to position 2
4. Watched the orange “I” light on dash. After it started to flash, I waited until after the third flash and let go of the trip reset button. From what I understand, the timing of this is important.
I shut off the car, closed my driver door and started the car. The maintenance message was reset.
Thanks JOFTAA. I followed your directions on my 2008 C70 and it worked like a charm.
hi
I have a 2007 V70 2.4 t5. I’ve tried the methods above but can’t get them to work, can anyone help me to reset the engine service light.
regards
This worked like a charm. “F” those dealers who are out to screw you out of money. You know if these dealers offer better support and not try to milk every penny out a customer more of us would go get serice from them.
Thanks for the tip.
I have tried these instructions numerous times with my V70, 2008, with no success. I either get a code “163″ and then a beep, and sometimes a code “040″. The image of the “wrench” does not disappear when these codes appear. The maintenance light reappears soon after.
Have you performed this technic successfully on a keyless ignition before? Do these codes tell you anything? (something I may be doing wrong?)
I will keep trying but would be interested if you have any feedback regarding the codes
Thanks
I have the same problem that adrian describes. I get a 040 code, then a 163 and a beep. The message is not removed..
How do I reset the service light?
Thanks JOFTAA It worked on my 2009 C70.
Sometimes I just love Internet… Works perfect on my C70 2010 D5. But I have to use the real key, not the “keless adapter”… Sorry I am Swedish, some holes in my English.
Thanks JOFTAA!
I know these comments are old but I’ll post my experience just for posterity. For those that cannot get JOFTAA’s instructions to work, make sure you’re not doing the same thi g wring that I was doing…
On the 2001 C70 there is a little button to the right of the key just below the dial that switches through information on the dash like temp, miles to 0, etc. This little button is actually marked “reset,” BUT IT’S THE WRONG BUTTON. I spent a long time holding down that pointless little bugger. If you follow JOFTAA’s steps and make sure you are indeed holding down the odometer reset button, it will probably work for you just like it did for me!
Hope that helps.
try these guys
V70
1999-2001
Turn the ignition switch to position I.
Press in trip meter RESET button. Turn ignition to position II.
When the TRIP METER RESET button has been pressed for 10 seconds, the SRL lamp starts to flash.
Release the TRIP METER RESET button within 5 seconds. The instrument produces a sound when resetting has been done successfully.
Turn the ignition off and then start the engine to verify the indicator has been reset.
2002-2005
Turn off ignition.
Press and hold in the TRIP METER RESET button, turn ignition on within 2 seconds.
Press and hold the RESET button for the trip odometer until the original value has been reset.
The information lamp lights up when the RESET button must be released. Release the RESET button for the trip odometer within 4 seconds.
Audible signal heard when resetting has been successful.
If the trip odometer has already been reset, the RESET button must be held a minimum of 10 seconds and a maximum of 14 seconds. Turn the ignition off and then start the engine to verify the indicator has been reset.
2006-2010
Reset may be similar to previous year or other models – Oil Reset will verify and update site.
All the advice looks promising but won’t work on my XC70 1998 model.
Anyone have any tips or tricks?
THANK YOU to TONYB!!! Tried it on my 2000 C70 and it worked perfectly! So perfectly, that I saved a lot of $$$ but I also passed my states emission test!! If you have a “service” light on, you will automatically fail, regardless if your emissions are up to standard requirements.
Does anyone know how to reset the service lights on a 2008 V50 Volvo station wagon after the service message changes from ” Time for regular service” to “Service overdue”?
Norm B
For you S-60 owners, this method of holding the trip button down and releasing it after 3 blinks worked for me as well. Thanks for the advice.
Thank you for the info!!!! I went to “SOMEOUTHER” website and “THY” wanted to charge me for the same info! This will save me $$ and gref from my Lady!!!
I had to press the keyless “start” button on my 2008 xc70 while I pressed the trip reset button and then I got the “i” to blink. I had been getting the 163 or 40 message. It worked finally. Thanks for the tips.
were is the o2 relay on a 1990-780 2.8
Does anyone know how to reset the service lights on a 2008 XC70 Volvo after the service message changes from ” Time for regular service” to “Service overdue”?
I found a way to shut service engine light off of my volvo V50 by doing the following
1. Push reset button
2. Put key into ignition
3. Turn to position 1 and wait 1 sec
4. Turn to position 2 and wait till light
blinks three times and then release button and start car at the same time. I hope this helps who needs it.
hello does anyone out there no ho to reset the (transmition service required)light on a 2001 xc v70.thanks
Does anyone know how to reset the time for regular maintenance on an 2007 s60 volvo?
PLease, help me reset the TIME FOR SERVICE LIGHT on my 2011 vc70 wagon??
I tried the reset technique with no success. So did what I have done with otehr cars — disconnect the battery for 15 seconds, reconnect, and voila. Done.
Can anyone tell me how to reset the service
Ight on a Volvo 850 1996 estate 2.5 se
Many thanks
Can someone help me with resetting the time for regular service message on Volvo S40 T5 2004 model. I have tried everything but not getting anywhere.
Thank you!
I couldn’t believe how easy it was.
Sal
What a huge help – tips like this is what makes this such a great site – THANKS!!!
hi…. somebody help me to reset my volovo t5 2006 service light
Thank you Scott J. I have going crazy holding the little reset button to get my service light off. It was the wrong button! One try with the odometer button and presto the light is off! Thanks to you.
Hey wondering if anyone can help, I have a 2008 c70 and I can’t get these procedures to work. I can get it to work on a c30 but not the c70 can anyone help?
