Volvo Repair Database
Reset Your Volvo’s Computer = Big Difference
How to do the reset? By simply starving the car’s ECU of electricity.
How to Zero out Your Volvo’s Computer and Make it Re-Learn your Driving Style
Since all 1990s and 2000s Volvos’ ECU’s haveĀ volatile memory and rely on a constant supply of 12 volts DC from the car, disconnecting the battery will do it. Follow the link below for more on this procedure.
“When my MAF sensor went bad, I changed the sensor and the car ran afterwards – but it was reaaaallllyyyy slow until the turbo picked up, and I noticed black smoke out the back. Once I reset the computer, it instantly had its pep back.”
Reset Your Volvo’s ECU
  1. Dash Computer Flashes DISC
  2. Reset Your Service Light: A How To
  3. Reset procedure for SRS
  4. S80 T6 2001 Service Light Reset How To
  5. Reset Service Light – Volvo
Tags
Bookmark permalink
6 Responses to Reset Your Volvo’s Computer = Big Difference
  1. Milos says:
    No problem
  2. Emil says:
    How do you do it on a V70 2.4T 2001 model? Not sure if disconnecting the battery will do it, or?
    Thanks,
    Emil
  3. ted goldberg says:
    disconnected battery on a 2001 V-70 ATSR 5 cyl non turbo and lost all computers trouble codes and cannot get computer to send any codes ,
    Would not start below 30 degrees , possible ignition or fuel problem
  4. ted goldberg says:
    Not sure how to reset computer , must it be replaced ? Dealer could not pinpoint the problem
  5. Matt says:
    Ted, please register and post your question in the Volvo V70 Forum.
    http://www.matthewsvolvosite.com/register-volvo-forum <- getting started
