July 1, 2009
S60 Trunk Latch Fix Tutorial
S60 Broken Trunk Latch Repair
The latch on my trunk recently started failing to latch. It turned my trunk into the ‘honour system’, so obviously I wanted to get that working again pronto!
I managed to without needing to buy any new parts, here’s a few hints if you run into this same problem:
Step 1: Remove interior trim on inside of trunk around latch. There is a bunch of snaps that just pull out with a little force.
S60 2002 Trunk Latch – Info on Fixing
Tags
